Update 4.7k
What's hot...
Update 4.7k
Update to Meteohub V4.7k (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
  • Some updates on vantage usb logger recovery procedure after usb connection getting dumb.
  • Realizes a code change that reports 0% humidity on WH-1080 TH sensors, when humidity goes below 10% which causes WH-1080 console to report invalid humidity data.
  • As a light weight alternative to "WD Live" I added the "Meteoware Live" App from Christian Warinsky. It takes the definitions on sensors given on the "WD Live" page of Meteohub. Please press "save" when done the with the config there. To make it working you also need to define an generation/upload schema on "Graph Uploads" page. You will find it there as "Meteoware-live" for SI units or "Meteoware-live US" for non-SI units as used in US and UK. The App makes use of the language defined for Meteohub. Predefined are German and English. You can add texts of other languages by providing translations in an appropriate language file. When you update your current language file on "maintenance" page, you will see new entries, wating for a translation. More details on how to embed Meteoware on your home page can be found at "live.meteoware.de".
Update Link: http://www.meteohub.de/files/update-v4.7k.upd
Re: Update 4.7k
Meteoware Live, German, in SI style:
Meteoware Live, English, in non-SI style:
