Update 4.7l
What's hot...
Update 4.7l
Update to Meteohub V4.7l (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
  • Fixes barometer bug when delivering pressure data to weather network MetOffice. Does now uwe station pressure instead of sealevel pressure.
  • Improves Vantage handling in case of USB hangs.
  • Fixes windspeed bug when sending data to "wetterring.at".
  • Major improvements on handling of adcon A850 data logger.
  • Finalizes code improvements for reading Vantage USB data loggers that are suffering from USB connection drops.
Update Link: http://www.meteohub.de/files/update-v4.7l.upd
gm4jjj
Re: Update 4.7l
Post by gm4jjj »
I have reverted to 4.7k on my Asus EeePC because since trying 4.7l I have twice had problems with the system stopping logging in the early morning. The first time it was the WMR100N USB communications (this happens very occasionally) and I had to reset the console. Then today after the daily scheduled restart the whole system stopped working, I couldn't ssh in to it and had to reboot the PC and VM completely.
Regarding the changes made to the way pressure is handled by WOW, this has now changed at WOW and the user can decide if they wish to use At Station or MSL pressure. I can therefore still run v4.7k and use WOW now with MSL pressure settings at WOW.
Of course the problems I experienced may be coincidence, but I think reverting to the stable 4.7k is sensible for me so that I can see if everything works OK again.
Have a good holiday.
David
wfpost
Re: Update 4.7l
Post by wfpost »
yep, versions l and m seem to have a bug.
my two plug-in weatherstations also stopped logging.
Returning to k and everything works fine.
Re: Update 4.7l
hm, cant imagine what might cause this.
when back from vacation i will have a look at it.
could you please give me details what exactly does not work as before?
paul_1055
Re: Update 4.7l
Post by paul_1055 »
Kann das oben genannte Problem bestätigen.
Mir ist es dadurch aufgefallen das beim Überschreiten der Haltedauer von 300s nicht versucht wird die Verbindung zur Wetterstation wieder aufzubauen.
wfpost
Re: Update 4.7l
Post by wfpost »
ja, daran scheint es zu liegen. Meine (Hardware-)Wetterstationen VP2 und RFX laufen ohne Probleme auch mit den Versionen l und m, weil dort eine Haltedauer von 300s eingestellt ist.
Aber bei den beiden (software-)plug-in´s sind 900 bzw. 600 s eingestellt und dort wird nur einmal der Wert geholt und dann stoppt die Aufzeichnung.
