Strange behavior with 2.2e (temp/hum) **solved**
najbo
Post by najbo »
I noticed strange values with following th0 values :
- temp. : max 1'802.6°C
- humidity : 255%
.. several times. What's up doc ;-) ?
It's a USB Davis Vantage Pro2 station.
Image [file name=log.txt size=12693]http://www.meteohub.de/joomla/images/fb ... es/log.txt[/file]
Re:Strange behavior with 2.2e (temp. / humidity)
Pretty hot there for April!
Any chance to logon to your system? please email to info(at)meteohub.de
I just checked the data. Reason is that Meteohub does not realized that sensor th0 is non providing correct data so far. Same error can occur in previous Meteohub versions. Will be fixed with the next update. Unfortunately, Davis does not document very well what sensor readings do indicate invalid data.
Bad raw data could be deleted with \"inspect data\" dialog, so on ongoing harm for the graphs.
