Sheevaplug & web interface username
lks6869
Post by lks6869 »
I noticed on the Meteohub user manual (v4.6) on page 4 it says about Sheevaplug: "This is still experimental with Meteohub".
When will Meteohub be out of the "experimental" stage and be in "production" stage onSheevaplug? (I wish I had known this info before I bought the units!)
Next question: How can I add an additional user name to the web interface? Through the web interface I can change the password but not the user name. The only user name available is "meteohub". I scanned through the manual but I didn't see a way to add a user name. Do I have to log in via SSH and do I have to be a linux guru to make the appropriate changes to have a second login user name??
Thank you.
Re: Sheevaplug & web interface username
it is in full production since about a year :-)
it will need linux skills to alter http access in the way you request it. but it is no magic. Learning a bit about Linux can never be wrong ;-)
wfpost
Post by wfpost »
:D
But, adding a user is very easy, but what groups permissions must this user have
to aquire full rights entering the WEBGUI?
useradd -p password -G root newuser
doesn´t allow this newuser accessing the GUI :roll:
lks6869
Post by lks6869 »
I'm wanting to add a user to the web interface only, not to the Linux system. I will search around and post results if I figure out how to do it...
Rainman32
Post by Rainman32 »
try 'htpasswd /srv/www/cgi-bin/.htpasswd (username)'
When things go wrong use 'reset-htpasswd' to reset to the default
