problem with installation with usb pen ... HELP!
mingoweb
Post by mingoweb »
Using the meteoHUB ALIX1d of 2 years and considering that the CFcard gave me problems I decided to format it.
My problem right now is that I can not install the meteoHUB why not say you start the USB image created "meteohub-v4.7-new.iso"
I set to boot from the USB tab alix1d, I loaded the image on the usb pendrive with Roadkil's Disk Image.
In pendrive usb I have the following files:
Where is that wrong? Why do not you start your usb pendrive?
Thanks for your help!
Re: problem with installation with usb pen ... HELP!
...because you did not use diskimage in physical disk mode. scroll down list of target drives until you get to there.
regards,
boris
wfpost
Post by wfpost »
yes, and you´re using Win7. Some folks have reported, that Roadkil's Disk Image (even the latest version) did not properly copy the image onto the USB-Stick.
As I have mentioned with another thread the Suse Image Writer is a tool that works perfect under Win7:
SUSE Studio ImageWriter for Microsoft Windows
http://en.opensuse.org/SDB:Live_USB_stick
