Update 4.7n
What's hot...
Update 4.7n
Update to Meteohub V4.7n (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
  • fixes a bug that variables with undefined sensors (like [day1_???_total_mm:-]) are not handled correctly. This had a negative effect on generating clientraw files in case of missing sensor definitions.
  • fixes a bug with peetbros stations. wind speed was about factor 1.46 too high (raw data assumed to be in mph but does come as kmh).
  • improved handling of vantage data logger in failure situations
Update Link: http://www.meteohub.de/files/update-v4.7n.upd
Re: Update 4.7n
If you had trouble with the latest versions in regard to vantage logging failures and plugins, please give this version a try.
YJB
Re: Update 4.7n
Post by YJB »
admin wrote:If you had trouble with the latest versions in regard to vantage logging failures and plugins, please give this version a try.
Thanks Boris, I've applied th update and will monitor closely. As you know, I had quite a few Vantage outages.
I will report back after some time, good or bad news.
Ysbrand
ZebraWetter
Location: Duisburg/northrhine-westfalia/germany/earth/sol system
Re: Update 4.7n
Post by ZebraWetter »
Great!
I'll drop an eye on it! I had a few smaller probs with the VP2, too.
paul_1055
Re: Update 4.7n
Post by paul_1055 »
Das Problem das kein Reboot / sync nach Überschreiten der Haltedauer von Live Daten erfolgt scheint behoben. Bei mit hat er heute jedenfalls nach Überschreiten von 300s sofort neu synchronisiert.
Mir scheint es das die Datenverbindung mit der VP2 insgesamt stabiler ist. Habe seit dem Update auf 4.7n erst ein einziges mal ein Überschreiten der Live Daten Haltedauer. Das gesamte Bild der Signalalter ist wesentlich gleichmäßiger und stabiler.
Station: VP2
Logger: Weatherlink-IP
Gruss Torsten
