I am about to try and describe what I need/require from the visual layout of the graph.
to start with there are two sensors on the same graph and both graph lines start from the left-hand side of the screen, but the scales for each graph are on opposite sides of the graph layout. One graph line is red and one green.
The ideal for me aesthetically is the :- left-hand start which is OK, one green and one red graph line which is OK. Now for the tricky bit, I want both scales to be on the left-hand side and the temperature scale colour to match the graph line, which would give a mixture of scale values on the left side. I am sure that this can be achieved from the Gnuplot command, but I do not know how to do it.
So if anybody has done this, I would be grateful for a little help.
