- fixed some data reception bugs for Peetbros Ultimeter stations
- dashboard update (version 2.3) that also supports language "Romana"
- support for "direct connect kit" (http://www.smartbedded.com) for cabled Davis Vantage Pro2 sensor units
- experimental support for Lufft WS600 UMB weather station
- experimental support for feeding live data in intervals down to 10 seconds onto a centralized server. Please switch on this feature (to be found on settings page, see image below) to allow for server performance evaluation. Having mastered performance next development step will be live data charting in terms of meters, gauges, etc.
Update 4.8a
Update 4.8a
Update to Meteohub V4.8a (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
- Unbenannt.PNG (3.98 KiB) Viewed 6878 times
Re: Update 4.8a
Update don´t work in meteohub ?
Error: Check md5sum of 4.8a failed (generate diff)!
mfg
martin
mfg
martin
Re: Update 4.8a
same here....martin150 wrote:Update don´t work in meteohub ?
Re: Update 4.8a
ooops, just fixed that. Please try again...
Re: Update 4.8a
now it works. Thank you!
Greetings
Mathias
Greetings
Mathias
Re: Update 4.8a
I am running 4.8a now, looks good.
Still hopping for the possibility to enter my historic weather records so that I have the correct values for highs and lows in WDL since 2006, that is the major thing I am missing, and that was what delayed my decision to move from WD to Meteohub the last year... I believe that this is the case for many longtime WD or other software users, the weather records as presented in WDL is of hugh importance....
Re: Update 4.8a
Works now !admin wrote:ooops, just fixed that. Please try again...
mfg
martin150
