Running meteohub on a raspberrypi
Hardware topics that do not fit in one of the other categories
geoair
Post by geoair »
Although it is not fully developed/available, I'm wondering if it would be possible to run  meteohub on a raspberrypi 'plug'.
Specs (info from wiki)
The first product is about the size of a credit card, and is designed to plug into a TV or be combined with a touch screen for a low cost tablet. The expected price is $25 for a fully-configured system.
  • 700MHz Broadcom media processor featuring an ARM11 (ARM1176JZF-S) core, Broadcom GPU core, DSP core and support for Package-on-Package (PoP) RAM
    128MiB (Model A) or 256MiB of SDRAM (Model B), stacked on top of the CPU as a PoP device
    OpenGL ES 2.0
    1080p30 H.264 high-profile decode
    Composite and HDMI video output
    One USB 2.0 port provided by the BCM2835
    SD/MMC/SDIO memory card slot
    General-purpose I/O (About 16 3v3) and various other interfaces, brought out to 1.27mm pin-strip
    Optional integrated 2-port USB hub and 10/100 Ethernet controller (Model B)
    Open software (Ubuntu, Iceweasel, KOffice, Python)
    Capability to support various expansion boards
Kind Regards,
Jorge
geoair
Re: Running meteohub on a raspberrypi
Post by geoair »
humm, no opinions?
Couldn't the raspberri py be a good platform to run meteohub?
many things can be done... but I doubt there is a significant market in the weather enthusiast arena for a naked board.
geoair
Post by geoair »
When you say naked,are you referring to the fact that it doesn't (yet) have an enclosure/case/box?If so, there're plans to make it available later or there's the option to do some DIY here and here.
But from a technical point of view, it would be possible?
Best regards,
Jorge
The B version of the board looks capable enough to me, that a meteohub port could be done. We ll see, when the units come out as planned in December. A $35 pricepoint for the naked board plus about $10 for housing and power supply will bring it up near to $50. Compared to a more powerful iConnect (in the Meteohub context - the rasberrypi has additional HDMI output which Meteohub does not make use of) which can be purchased in the US for $60 - $70 and for 30 GBP from Cyrrus in UK it is not such a bargain. However, when the units are available I will have a look at it.
geoair
Post by geoair »
Does Cyrrus in UK have a website?
I'm also considering the iomega iconnect + meteohub combo (although a bit expensive for my wallet) to replace my desktop running 24/7/365 to share my VP2 weather data but here in Portugal the offer of the Iomega is scarse and (very) expensive...
Best regards
cyrrus does only sell in stores in uk, as far as i know.
geoair
Post by geoair »
admin wrote:cyrrus does only sell in stores in uk, as far as i know.
OK, thanks anyway for the info.
Regards,
kathi
Post by kathi »
Ok. Thanks for the reply. And 'Expected in the future the possibility of using the wmr300 with Meteohub?
If you are looking for fast success in vce to pdf then join convert vce to pdf to find complete open vce file resources and pass www.ndm.edu certifications on first try. A person can pick Johnson University Florida
