error connect socket 127.0.0.1:5555 :Connection refused
ianwright
Post by ianwright »
I´ve been playing with the evaluation version and was just about to purchase the software when the dreaded "error connect socket 127.0.0.1:5555 :Connection refused" appeared. In the process of evaluating the software I have changed any number of things but as far as I recall the system went from working to not working without their being any obvious reason.
Although I had only had the system up and running for a few weeks I assumed that the brand new usb stick was at fault. Consequently I prepared a fresh version on an old stick I had. Same problem.
I´ve noticed two things:
1) Under the Weather Station tab I see the following USB serial none USB HID none
2) Under the Licence tab the licence terms for weather display live are not found but the Meteohub ones are there.
Any ideas?
Ian
Re: error connect socket 127.0.0.1:5555 :Connection refused
2) is a bug that will be fixed with next update
1) indicates that your weather station and/or usb-serial adapter is not recognized/connected. This causes the data logger to restart again an again which results the data logger not providing status data on its sockets, which results in the sensors page not beeing able to connect to these. Get the weather station setup/connection issue solved and you wont see the socket errors again.
Joe200
Post by Joe200 »
admin wrote:2) is a bug that will be fixed with next update
I had the same problem some time ago and till now I couldn't solve it. How can I get the weather station setup/connection issue solved? My weather station is Oregon WMR200 and the problem happened with no warning...
Error file open /home/meteohub/meteohub.conf
Warning: Data logging has been halted.
And on every page of meteohub I have an error saying: Error file open /home/meteohub/meteohub.conf
How can I solve all this?
setup system from scratch. your flash storage media is broken.
