Alix 2D13
stefferber
Alix 2D13
Post by stefferber »
After two weekends of trying I gave up to install metehub on my Alix 2D13 LX800. The boot process always stalled after the ready message.
PC Engines ALIX.2 v0.99h
640 KB Base Memory
261120 KB Extended Memory
01F0 Master 044A CF CARD 8GB
Phys C/H/S 15538/16/63 Log C/H/S 974/255/63 LBA
SYSLINUX 3.63 Debian-2008-04-10 EBIOS Copyright (C) 1994-2008 H. Peter Anvin
Loading linux.........................
Loading initrd.gz...................................................................................ready.
I tried different CF cards, USB stick, and a standard Debian Linux Image. All failed. The only software I could make run on the Alix 2D was IPCop 1.4 CF image http://www.ipcop-forum.de/index.php
I ordered a DreamPlug today so I will not continue to work on Alix. Just in case somebody else has the same problem: You are not allone...
Re: Alix 2D13
Hardware section on meteohub.de cleary says that ALIX1D, ALIX3D2 and ALIX3D3 are supported.
So I am not too surprised that your series 2 ALIX board does not do.
stefferber
Re: Alix 2D13
Yes, I know that Alix 2D was not included in the list. From what I learned in the IPCop Forum it is possbile to tweak a Debian to all Alix boards...
xor
Re: Alix 2D13
Post by xor »
up!!! syslinux bootloader on pendrive! on meteohab grub!
you put on the wrong image cf
hello!
I meteohab runs on platforms 2D2 and 6F2
PC Engines ALIX.6 v0.99j
on the platform without vga output and keyboard port input / output to be redirected to the com port.
try using GRUB and all output is sent ttyS0
serial --speed=38400
terminal serial
...root=/dev/hda1 ro quiet console=ttyS0,38400n8
/etc/inittab
#1:2345:respawn:/sbin/getty 38400 tty1
#2:23:respawn:/sbin/getty 38400 tty2
#3:23:respawn:/sbin/getty 38400 tty3
#4:23:respawn:/sbin/getty 38400 tty4
#5:23:respawn:/sbin/getty 38400 tty5
#6:23:respawn:/sbin/getty 38400 tty6
T0:23:respawn:/sbin/getty -L ttyS0 38400
