Sheevaplug not responding
lks6869
Post by lks6869 »
I had 4 Shevaplugs (WeatherHub2), purchased a few months ago, and I just bought another brand new one. I was able to ping it and access its web pages.
On one of my original units I had saved a backup file of all settings (Maintenance tab, Backup Settings). On my new unit I loaded the backup settings in order to quickly set it up. Now it appears to be totally dead, I can't ping it or access it's web pages at either the default IP 192.168.1.77 or the new IP that was in the backup config file. I've spent over an hour and I can't communicate with it at all.
I've also tried the ipscan tool and it doesn't see it either.
Even if I changed the IP address should I still be able to see it at 192.168.1.77?? (The manual says that on page 23)
What should I do now? Should I reformat the SD card to its factory default?
lks6869
Re: Sheevaplug not responding
Post by lks6869 »
Ok, for some reason, after trying for an hour I am suddenly able to communicate with it at 192.168.1.77. But I can only get to the Maintenance page and it tells me Demo version has timed out. Did my license get destroyed because I loaded Backup Settings from a different unit?
Yes, activation code is part of the stored set of data.
When you don't have your activation code noticed anywhere, please do mail the system id of the Meteohub that lost activation to "info(at)meteohub.de".
