Upgrade 4gb to 8gb SD-Card on SheevaPlug?
ON1DQD
Post by ON1DQD »
Is there an easy way to upgrade a 4gb to 8gb SD-Card?
Can i use some software (windows environment) to copy the current 4gb to the new 8gb and that rezise the 3rd partition with an partition manager?
Regards / Grüß,
Geert - ON1DQD
Re: Upgrade 4gb to 8gb SD-Card on SheevaPlug?
hi, there is a detailed report somewhere in this forum how to enlarge the data partition on a running meteohub system.
When you search a bit you should find it.
....found it
viewtopic.php?f=25&t=5943&p=5945&hilit=resize2fs#p5945
ON1DQD
Post by ON1DQD »
Yes, I already found this post but I need to now what is the best way to copy my current 4gb SD-Card to my new 8gb SD-Card.
And if possible under windows :|
Regards / Grüß,
Geert - ON1DQD
MeteoSheeva
Post by MeteoSheeva »
It works easily with a GParted-LiveCD.
The only things you need are two SD-card readers. It works for example with an internal reader of a laptop and an USB card reader.
Then plug in the old and new card and boot from the GParted-CD.
There you can copy and paste the content from the old card to the new card and expand the data-partition.
"The thing about quotes on the internet is you can not confirm their validity"
        - Abraham Lincoln
