New Installation
awesterhoff
New Installation
Post by awesterhoff »
I've used meteohub on the nslu2 for a while but it broke.
So, got another usb stick and used roadkills disk image to store the dd file from the 4.7 image and all went ok.
According to the manual I should stick in the usb stich with the image in port 2.
I have turned on the power and it started.....
But off course it isn't working correctly.
I found out that I can login using ssh, but it's an "empty Linux system", no meteohub on it.
I tried several things already.
Please advise
Re: New Installation
USB stick has not been prepared correctly, therefore, Meteohub does not get booted.
Please use "physical disk" option with DiskImage, otherwise stick it will not work.
awesterhoff
just a matter of "reading what's in the combobox" ................
