Update 4.8f
What's hot...
Update 4.8f
Update to Meteohub V4.8f (NSLU2, x86, SheevaPlug, DreamPlug) brings these features:
  • added WH-1080 clones from Ambientweather to list of stations to select from
  • added an "imperial unit" flag to the left of language selector on "settings" page to have data reported on "sensors" page in °F, inHg, in/h, etc). This also changes station altitude specification on "weather station" page from m to ft.
  • only valid for iConnect users: update on iConnect system ID computation. This will require a one time reactivation of already activated iConnect Meteohub licenses after having done the update. License key you received via email is activated again, so you can generate a new activation code for the new system ID as you did when you started with the iConnect.
  • displays some info about used storage media on "system info" page
Update Link: http://www.meteohub.de/files/update-v4.8f.upd
FacEngRet
Re: Update 4.8f
Post by FacEngRet »
I have applied the 4.8f update to my iConnect and followed the steps to generate a new activation code. I have tried to apply the new code but it does not seem to do anything as I am now stuck in 90 day demo mode.
Re: Update 4.8f
When inserting the system ID you have smuggled in 3 leading blanks in front of the ID. System does not skip that. Please try again, your license key is reactivated.
FacEngRet
Re: Update 4.8f
Post by FacEngRet »
Thank you!
All is working now. My fault due to a sloppy copy and paste. :oops:
wrj0
Re: Update 4.8f
Post by wrj0 »
Boris,
Many thanks for the Imperial Unit flag addition. That's very helpful for those of us going metric an inch at a time.
