Transcend USB Card Reader P6 is not SD compatible
geoair
Post by geoair »
HI,
Just one heads up for those who are searching a SD Card Reader: the Transcend's P6 TS-RDP6k is not compatible with SD Cards, it only supports - Memory Stick; Memory Stick PRO; Memory Stick Duo; Memory Stick PRO Duo; Memory Stick PRO-HG Duo; Memory Stick Micro (M2); microSDHC; microSD / TransFlash.
To suport SD cards it must be the P5 version: TS-RDP5; TS-RDP5K or TS-RDP5W
I know because I ordered a P6 and when I received saw that the SD card is not supported... :?
Regards,
Jorge
Re: Transcend USB Card Reader P6 is not SD compatible
I found these three card readers from Transcend and SanDisk working, with the MicroMate being most expensive but alo best physically shielding a SD card. Product names I found on these are (from left to right): RDS5, SDDR-113, P5/P6
card reader.jpg (84.78 KiB) Viewed 2886 times
