error receive data from socket 127.0.0.1:5555
Headworx
Post by Headworx »
Dear,
From time to time (2-3 times a month) I keep getting the following error:
error receive data from socket 127.0.0.1:5555: Resource temporarily unavailable
Warning: Data logging has been halted.
After my recent upgrade to 4.8 (Build 789) it happens every second day. I run quite heavily loaded SheevaPlug (6 weather stations: 1 Davis, 3 RFXCom, system data and virtual (simple bash plugin).
What is the reason of this error and what can I do to fix it?
Cheers,
Headworx
Re: error receive data from socket 127.0.0.1:5555
What does "meteohub log" tell?
When the logger restarts/stops the message apaers, as the Meteohub GUI does read curent data for "sensors" page by a tcp read request to the logger. The error indicates, that the logger does not respond on the request.
Headworx
Post by Headworx »
The logs are empty. Only dmesg shows some entries, the rest of the logs are blank.
Headworx
Post by Headworx »
Boris, any idea how to proceed with this issue? My stations are not recording any data for several weeks now...
do i have a chance to login remotely?
Headworx
Post by Headworx »
Yes sure. Is port 22 / SSH enough? I will have to reconfigure the router. I will do this on Saturday, so you are welcome to have a look at it just after Christmas.
ports 22 and 7777 would be fine. please send credentials (WAN IP etc) to "info(at)meteohub.de" attached with a short failure description or link to this thread, so I can remember... I get plenty of mails ;-)
