day1 data missing ?
BooX
day1 data missing ?
Post by BooX »
Hi
My Meteohub running on a NSLU2 has stopped providing day1_xxxx_xxxx data.
A http://METEOHUB_IP/meteograph.cgi?text=all shows all data except for the day1_xxxx_xxxx, month and year are present as always.
I have looked thru the data for the last 4 days and don't see any corrupted data.
If you take a look at my website http://weather.flybilleder.dk/ you will also see that the day1 data is missing.
Is this a usb-stick on the edge of dying or ???
Thank you in advance.
Best regards
Bo
BooX
Re: day1 data missing ?
Post by BooX »
This is the reply from http://METEOHUB_IP/meteograph.cgi?text=all ( I've deleted the seq data due to max. 60000 characters )
actual_utcdate 20111213203459
actual_utcdate2 13.12.2011 20:34:59
actual_date0_puredate_utc 13.12.2011
actual_date0_time_utc 20:34:59
actual_date0_year_utc 2011
actual_date0_month_utc 12
actual_date0_day_utc 13
actual_date0_dayofweek_utc 2
actual_date0_hour_utc 20
actual_date0_min_utc 34
actual_date0_sec_utc 59
actual_localdate 20111213213459
actual_localdate2 13.12.2011 21:34:59
actual_date0_puredate_local 13.12.2011
actual_date0_time_local 21:34:59
actual_date0_year_local 2011
actual_date0_month_local 12
actual_date0_day_local 13
actual_date0_dayofweek_local 2
actual_date0_hour_local 21
actual_date0_min_local 34
actual_date0_sec_local 59
actual_lunar_phase_percentage 89.3
actual_lunar_age_days 17
actual_lunar_phase_segment 5
actual_lunar_phase_de Dreiviertelmond_(abnehmend)
actual_lunar_phase_en Waning_Gibbous
actual_lunar_phase_es Gibosa_Menguante
actual_lunar_phase_nl Afnemende_maan
actual_lunar_phase_dk_iso Mere_end_halv,_aftagende
actual_lunar_phase_dk_html Mere_end_halv,_aftagende
actual_lunar_phase_cz_html Couvající_Měsíc
actual_station_longitude_decimal 9.158611
actual_station_latitude_decimal 55.569722
actual_daylength_standard_hours  7.13
actual_daylength_standard_minutes 428
actual_daylength_standard_hhmm 07:08
actual_daylength_civiltwilight_hours  8.67
actual_daylength_civiltwilight_minutes 520
actual_daylength_civiltwilight_hhmm 08:40
actual_daylength_nauticaltwilight_hours 10.28
actual_daylength_nauticaltwilight_minutes 617
actual_daylength_nauticaltwilight_hhmm 10:17
actual_sunrise_standard_utc 07:43
actual_sunset_standard_utc 14:51
actual_sunrise_standard_local 08:43
actual_sunset_standard_local 15:51
actual_sunrise_civiltwilight_utc 06:57
actual_sunset_civiltwilight_utc 15:37
actual_sunrise_civiltwilight_local 07:57
actual_sunset_civiltwilight_local 16:37
actual_sunrise_nauticaltwilight_utc 06:09
actual_sunset_nauticaltwilight_utc 16:26
actual_sunrise_nauticaltwilight_local 07:09
actual_sunset_nauticaltwilight_local 17:26
actual_moonrise_standard_local 19:07
actual_moonrise_standard_utc 18:07
actual_moonset_standard_local 10:27
actual_moonset_standard_utc 09:27
actual_thb0_temp_c 20.0
actual_thb0_temp_f 68.0
actual_thb0_hum_rel 46
actual_thb0_hum_abs 7.9
actual_thb0_dew_c 8.0
actual_thb0_dew_f 46.4
actual_thb0_heatindex_c 20.0
actual_thb0_heatindex_f 68.0
actual_thb0_humidex_c 20.4
actual_thb0_humidex_f 68.7
actual_thb0_cloudheight_m 1500
actual_thb0_cloudheight_ft 4800
actual_thb0_press_hpa 976.8
actual_thb0_press_psi 14.17
actual_thb0_press_mmhg 732.6
actual_thb0_press_inhg 28.84
actual_thb0_sealevel_hpa 986.2
actual_thb0_sealevel_psi 14.30
actual_thb0_sealevel_mmhg 739.7
actual_thb0_sealevel_inhg 29.12
actual_thb0_fc 0
actual_thb0_fc_wdlive 20
actual_thb0_fc_rule 192
actual_thb0_fc_text Mostly_cloudy_and_cooler._Precipitation_possible_within_12_hours,_possibly_heavy_at_times._Windy.
actual_solar_irradiance_wqm 112
actual_th0_temp_c 4.5
actual_th0_temp_f 40.1
actual_th0_hum_rel 46
actual_th0_hum_abs 3.0
actual_th0_dew_c -6.1
actual_th0_dew_f 21.0
actual_th0_heatindex_c 4.5
actual_th0_heatindex_f 40.1
actual_th0_humidex_c 1.1
actual_th0_humidex_f 34.0
actual_th0_cloudheight_m 1325
actual_th0_cloudheight_ft 4240
actual_wind0_dir_deg 201
actual_wind0_dir_de SSW
actual_wind0_dir_en SSW
actual_wind0_gustspeed_ms 2.7
actual_wind0_gustspeed_kmh 9.7
actual_wind0_gustspeed_mph 6.0
actual_wind0_gustspeed_kn 5.2
actual_wind0_gustspeed_bft 2.2
actual_wind0_speed_ms 1.8
actual_wind0_speed_kmh 6.5
actual_wind0_speed_mph 4.0
actual_wind0_speed_kn 3.5
actual_wind0_speed_bft 1.7
actual_wind0_chill_c 2.1
actual_wind0_chill_f 35.8
actual_rain0_rate_mm 0.0
actual_rain0_rate_in 0.00
actual_rain0_total_mm 1031.0
actual_rain0_total_in 40.59
actual_t0_temp_c 22.7
actual_t0_temp_f 72.9
actual_t1_temp_c 4.0
actual_t1_temp_f 39.2
actual_t2_temp_c 20.3
actual_t2_temp_f 68.5
actual_data0_value_num 0.00
actual_data0_value_int 0
alltime_utcdate 20111213022637
alltime_localdate 20111213032637
alltime_wind0_maxspeeddir_deg 247.5
alltime_wind0_maxspeeddir_de WSW
alltime_wind0_maxspeeddir_en WSW
alltime_wind0_maindir_deg 225.0
alltime_wind0_maindir_de SW
alltime_wind0_maindir_en SW
alltime_wind0_gustspeed_ms 2.6
alltime_wind0_gustspeed_kmh 9.4
alltime_wind0_gustspeed_mph 5.9
alltime_wind0_gustspeed_kn 5.1
alltime_wind0_gustspeed_bft 2.1
alltime_wind0_gustspeedmin_time 20100820183456
alltime_wind0_gustspeedmin_ms 0.0
alltime_wind0_gustspeedmin_kmh 0.0
alltime_wind0_gustspeedmin_mph 0.0
alltime_wind0_gustspeedmin_kn 0.0
alltime_wind0_gustspeedmin_bft 0.0
alltime_wind0_gustspeedmax_time 20110207224134
alltime_wind0_gustspeedmax_deg 240
alltime_wind0_gustspeedmax_ms 26.8
alltime_wind0_gustspeedmax_kmh 96.5
alltime_wind0_gustspeedmax_mph 60.0
alltime_wind0_gustspeedmax_kn 52.1
alltime_wind0_gustspeedmax_bft 10.1
alltime_wind0_speed_ms 2.6
alltime_wind0_speed_kmh 9.4
alltime_wind0_speed_mph 5.8
alltime_wind0_speed_kn 5.1
alltime_wind0_speed_bft 2.1
alltime_wind0_speedmin_time 20100820184822
alltime_wind0_speedmin_ms 0.0
alltime_wind0_speedmin_kmh 0.0
alltime_wind0_speedmin_mph 0.0
alltime_wind0_speedmin_kn 0.0
alltime_wind0_speedmin_bft 0.0
alltime_wind0_speedmax_time 20110207222126
alltime_wind0_speedmax_deg 246
alltime_wind0_speedmax_ms 14.8
alltime_wind0_speedmax_kmh 53.3
alltime_wind0_speedmax_mph 33.1
alltime_wind0_speedmax_kn 28.8
alltime_wind0_speedmax_bft 6.8
alltime_wind0_chill_c 6.7
alltime_wind0_chillmin_time 20101225084413
alltime_wind0_chillmax_time 20110627160644
alltime_wind0_chillmin_c -20.2
alltime_wind0_chillmax_c 26.4
alltime_wind0_chill_f 44.0
alltime_wind0_chillmin_f -4.4
alltime_wind0_chillmax_f 79.5
alltime_rain0_rate_mm 0.3
alltime_rain0_rate_in 0.01
alltime_rain0_ratemin_time 20100820182924
alltime_rain0_ratemin_mm 0.0
alltime_rain0_ratemin_in 0.00
alltime_rain0_ratemax_time 20110619112414
alltime_rain0_ratemax_mm 1440.0
alltime_rain0_ratemax_in 56.69
alltime_rain0_total_mm 1380.20
alltime_rain0_total_in 54.34
alltime_rain0_total_time 20111206184335
alltime_rain0_days 297
alltime_thb0_temp_c 19.2
alltime_thb0_temp_f 66.6
alltime_thb0_tempmin_time 20110505090927
alltime_thb0_tempmax_time 20110604194727
alltime_thb0_tempmin_c 14.9
alltime_thb0_tempmin_f 58.8
alltime_thb0_tempmax_c 25.6
alltime_thb0_tempmax_f 78.1
alltime_thb0_temp_trend -1
alltime_thb0_dew_c 8.7
alltime_thb0_dew_f 47.6
alltime_thb0_dewmin_time 20101130151526
alltime_thb0_dewmax_time 20110730195328
alltime_thb0_dewmin_c -1.3
alltime_thb0_dewmin_f 29.7
alltime_thb0_dewmax_c 17.4
alltime_thb0_dewmax_f 63.3
alltime_thb0_dew_trend -1
alltime_thb0_heatindex_c 19.2
alltime_thb0_heatindex_f 66.6
alltime_thb0_heatindexmin_time 20110505090927
alltime_thb0_heatindexmax_time 20110604194727
alltime_thb0_heatindexmin_c 14.9
alltime_thb0_heatindexmin_f 58.8
alltime_thb0_heatindexmax_c 25.6
alltime_thb0_heatindexmax_f 78.1
alltime_thb0_heatindex_trend -1
alltime_thb0_humidex_c 20.1
alltime_thb0_humidex_f 68.2
alltime_thb0_humidexmin_time 20110505094027
alltime_thb0_humidexmax_time 20110730195328
alltime_thb0_humidexmin_c 13.4
alltime_thb0_humidexmin_f 56.1
alltime_thb0_humidexmax_c 30.8
alltime_thb0_humidexmax_f 87.4
alltime_thb0_humidex_trend -1
alltime_thb0_hum_rel 51.1
alltime_thb0_hummin_time 20101130151426
alltime_thb0_hummax_time 20100821112422
alltime_thb0_hummin_rel 30.0
alltime_thb0_hummax_rel 74.0
alltime_thb0_hum_trend -1
alltime_thb0_press_hpa 1005.1
alltime_thb0_press_psi 14.58
alltime_thb0_press_mmhg 753.8
alltime_thb0_press_inhg 29.68
alltime_thb0_pressmin_time 20101112074028
alltime_thb0_pressmax_time 20110301230328
alltime_thb0_pressmin_hpa 960.7
alltime_thb0_pressmin_psi 13.93
alltime_thb0_pressmin_mmhg 720.5
alltime_thb0_pressmin_inhg 28.37
alltime_thb0_pressmax_hpa 1033.1
alltime_thb0_pressmax_psi 14.98
alltime_thb0_pressmax_mmhg 774.8
alltime_thb0_pressmax_inhg 30.51
alltime_thb0_press_trend -1
alltime_thb0_sealevel_hpa 1014.5
alltime_thb0_sealevel_psi 14.71
alltime_thb0_sealevel_mmhg 760.9
alltime_thb0_sealevel_inhg 29.96
alltime_thb0_sealevelmin_time 20101112074028
alltime_thb0_sealevelmax_time 20110301230328
alltime_thb0_sealevelmin_hpa 970.1
alltime_thb0_sealevelmin_psi 14.07
alltime_thb0_sealevelmin_mmhg 727.6
alltime_thb0_sealevelmin_inhg 28.65
alltime_thb0_sealevelmax_hpa 1042.5
alltime_thb0_sealevelmax_psi 15.12
alltime_thb0_sealevelmax_mmhg 781.9
alltime_thb0_sealevelmax_inhg 30.78
alltime_th0_temp_c 8.1
alltime_th0_temp_f 46.6
alltime_th0_tempmin_time 20101226024027
alltime_th0_tempmax_time 20110627160644
alltime_th0_tempmin_c -15.3
alltime_th0_tempmin_f 4.5
alltime_th0_tempmax_c 26.4
alltime_th0_tempmax_f 79.5
alltime_th0_temp_trend -1
alltime_th0_dew_c 5.1
alltime_th0_dew_f 41.1
alltime_th0_dewmin_time 20101226015623
alltime_th0_dewmax_time 20110826134342
alltime_th0_dewmin_c -16.7
alltime_th0_dewmin_f 1.9
alltime_th0_dewmax_c 19.7
alltime_th0_dewmax_f 67.5
alltime_th0_dew_trend -1
alltime_th0_heatindex_c 8.1
alltime_th0_heatindex_f 46.6
alltime_th0_heatindexmin_time 20101226024027
alltime_th0_heatindexmax_time 20110627160644
alltime_th0_heatindexmin_c -15.3
alltime_th0_heatindexmin_f 4.5
alltime_th0_heatindexmax_c 26.4
alltime_th0_heatindexmax_f 79.5
alltime_th0_heatindex_trend -1
alltime_th0_humidex_c 7.9
alltime_th0_humidex_f 46.1
alltime_th0_humidexmin_time 20101226024027
alltime_th0_humidexmax_time 20110731153758
alltime_th0_humidexmin_c -19.9
alltime_th0_humidexmin_f -3.8
alltime_th0_humidexmax_c 32.5
alltime_th0_humidexmax_f 90.5
alltime_th0_humidex_trend -1
alltime_th0_hum_rel 82.7
alltime_th0_hummin_time 20110429170127
alltime_th0_hummax_time 20100930062342
alltime_th0_hummin_rel 29.0
alltime_th0_hummax_rel 100.0
alltime_th0_hum_trend -1
alltime_t0_temp_c 21.0
alltime_t0_temp_f 69.8
alltime_t0_tempmin_time 20111128185801
alltime_t0_tempmax_time 20111112141530
alltime_t0_tempmin_c 0.2
alltime_t0_tempmin_f 32.4
alltime_t0_tempmax_c 85.0
alltime_t0_tempmax_f 185.0
alltime_t0_temp_trend 1
alltime_t1_temp_c 12.4
alltime_t1_temp_f 54.3
alltime_t1_tempmin_time 20110327071305
alltime_t1_tempmax_time 20110731153023
alltime_t1_tempmin_c -5.4
alltime_t1_tempmin_f 22.3
alltime_t1_tempmax_c 30.1
alltime_t1_tempmax_f 86.2
alltime_t1_temp_trend -1
alltime_t2_temp_c 19.2
alltime_t2_temp_f 66.6
alltime_t2_tempmin_time 20110321172550
alltime_t2_tempmax_time 20110604152039
alltime_t2_tempmin_c 1.8
alltime_t2_tempmin_f 35.2
alltime_t2_tempmax_c 34.0
alltime_t2_tempmax_f 93.2
alltime_t2_temp_trend 0
alltime_data0_value_num 0.06
alltime_data0_value_int 0
alltime_data0_valuemin_num 0.00
alltime_data0_valuemax_num 0.30
alltime_data0_valuemin_int 0
alltime_data0_valuemax_int 0
alltime_data0_valuemin_time 20111128191135
alltime_data0_valuemax_time 20111201160746
alltime_data0_valuerise 111
alltime_data0_valuefall 111
alltime_data0_valuesum_num 20.40
alltime_data0_valuesum_int 20
alltime_data0_valuesumpermin_num 0.00
alltime_data0_valuesumpermin_int 0
alltime_data0_valuedeltasum_num 1270.00
alltime_data0_valuedeltasum_int 1270
day1_utcdate 20111213203016
day1_localdate 20111213213016
hour1_utcdate 20111213203028
hour1_localdate 20111213213028
last15m_utcdate 20111213203052
last15m_localdate 20111213213052
last24h_utcdate 20111213203040
last24h_localdate 20111213213040
last60m_utcdate 20111213203046
last60m_localdate 20111213213046
month1_utcdate 20111213171857
month1_localdate 20111213181857
month1_wind0_maxspeeddir_deg 202.5
month1_wind0_maxspeeddir_de SSW
month1_wind0_maxspeeddir_en SSW
month1_wind0_maindir_deg 202.5
month1_wind0_maindir_de SSW
month1_wind0_maindir_en SSW
month1_wind0_gustspeed_ms 2.7
month1_wind0_gustspeed_kmh 9.9
month1_wind0_gustspeed_mph 6.1
month1_wind0_gustspeed_kn 5.3
month1_wind0_gustspeed_bft 2.2
month1_wind0_gustspeedmin_time 20111201000052
month1_wind0_gustspeedmin_ms 0.0
month1_wind0_gustspeedmin_kmh 0.0
month1_wind0_gustspeedmin_mph 0.0
month1_wind0_gustspeedmin_kn 0.0
month1_wind0_gustspeedmin_bft 0.0
month1_wind0_gustspeedmax_time 20111203114008
month1_wind0_gustspeedmax_deg 197
month1_wind0_gustspeedmax_ms 17.9
month1_wind0_gustspeedmax_kmh 64.4
month1_wind0_gustspeedmax_mph 40.0
month1_wind0_gustspeedmax_kn 34.8
month1_wind0_gustspeedmax_bft 7.7
month1_wind0_speed_ms 2.7
month1_wind0_speed_kmh 9.8
month1_wind0_speed_mph 6.1
month1_wind0_speed_kn 5.3
month1_wind0_speed_bft 2.2
month1_wind0_speedmin_time 20111201002226
month1_wind0_speedmin_ms 0.0
month1_wind0_speedmin_kmh 0.0
month1_wind0_speedmin_mph 0.0
month1_wind0_speedmin_kn 0.0
month1_wind0_speedmin_bft 0.0
month1_wind0_speedmax_time 20111203114626
month1_wind0_speedmax_deg 232
month1_wind0_speedmax_ms 8.9
month1_wind0_speedmax_kmh 32.0
month1_wind0_speedmax_mph 19.9
month1_wind0_speedmax_kn 17.3
month1_wind0_speedmax_bft 4.8
month1_wind0_chill_c 1.3
month1_wind0_chillmin_time 20111205074146
month1_wind0_chillmax_time 20111201131036
month1_wind0_chillmin_c -5.9
month1_wind0_chillmax_c 7.7
month1_wind0_chill_f 34.4
month1_wind0_chillmin_f 21.4
month1_wind0_chillmax_f 45.9
month1_rain0_rate_mm 0.5
month1_rain0_rate_in 0.02
month1_rain0_ratemin_time 20111201000012
month1_rain0_ratemin_mm 0.0
month1_rain0_ratemin_in 0.00
month1_rain0_ratemax_time 20111201181322
month1_rain0_ratemax_mm 22.0
month1_rain0_ratemax_in 0.87
month1_rain0_total_mm 43.60
month1_rain0_total_in 1.72
month1_rain0_total_time 20111206184335
month1_rain0_days 6
month1_thb0_temp_c 19.2
month1_thb0_temp_f 66.5
month1_thb0_tempmin_time 20111204162825
month1_thb0_tempmax_time 20111201230026
month1_thb0_tempmin_c 17.8
month1_thb0_tempmin_f 64.0
month1_thb0_tempmax_c 20.6
month1_thb0_tempmax_f 69.1
month1_thb0_temp_trend -1
month1_thb0_dew_c 8.1
month1_thb0_dew_f 46.5
month1_thb0_dewmin_time 20111205145325
month1_thb0_dewmax_time 20111201230026
month1_thb0_dewmin_c 6.0
month1_thb0_dewmin_f 42.8
month1_thb0_dewmax_c 9.8
month1_thb0_dewmax_f 49.6
month1_thb0_dew_trend -1
month1_thb0_heatindex_c 19.2
month1_thb0_heatindex_f 66.5
month1_thb0_heatindexmin_time 20111204162825
month1_thb0_heatindexmax_time 20111201230026
month1_thb0_heatindexmin_c 17.8
month1_thb0_heatindexmin_f 64.0
month1_thb0_heatindexmax_c 20.6
month1_thb0_heatindexmax_f 69.1
month1_thb0_heatindex_trend -1
month1_thb0_humidex_c 19.6
month1_thb0_humidex_f 67.4
month1_thb0_humidexmin_time 20111205145325
month1_thb0_humidexmax_time 20111201230026
month1_thb0_humidexmin_c 17.4
month1_thb0_humidexmin_f 63.3
month1_thb0_humidexmax_c 21.8
month1_thb0_humidexmax_f 71.2
month1_thb0_humidex_trend -1
month1_thb0_hum_rel 48.5
month1_thb0_hummin_time 20111204145225
month1_thb0_hummax_time 20111201211826
month1_thb0_hummin_rel 46.0
month1_thb0_hummax_rel 51.0
month1_thb0_hum_trend -1
month1_thb0_press_hpa 985.2
month1_thb0_press_psi 14.29
month1_thb0_press_mmhg 738.9
month1_thb0_press_inhg 29.09
month1_thb0_pressmin_time 20111205011128
month1_thb0_pressmax_time 20111201000028
month1_thb0_pressmin_hpa 973.9
month1_thb0_pressmin_psi 14.12
month1_thb0_pressmin_mmhg 730.4
month1_thb0_pressmin_inhg 28.76
month1_thb0_pressmax_hpa 1007.9
month1_thb0_pressmax_psi 14.62
month1_thb0_pressmax_mmhg 755.9
month1_thb0_pressmax_inhg 29.76
month1_thb0_press_trend 0
month1_thb0_sealevel_hpa 994.6
month1_thb0_sealevel_psi 14.43
month1_thb0_sealevel_mmhg 746.0
month1_thb0_sealevel_inhg 29.37
month1_thb0_sealevelmin_time 20111205011128
month1_thb0_sealevelmax_time 20111201000028
month1_thb0_sealevelmin_hpa 983.3
month1_thb0_sealevelmin_psi 14.26
month1_thb0_sealevelmin_mmhg 737.5
month1_thb0_sealevelmin_inhg 29.04
month1_thb0_sealevelmax_hpa 1017.3
month1_thb0_sealevelmax_psi 14.75
month1_thb0_sealevelmax_mmhg 763.0
month1_thb0_sealevelmax_inhg 30.04
month1_th0_temp_c 3.4
month1_th0_temp_f 38.0
month1_th0_tempmin_time 20111206034904
month1_th0_tempmax_time 20111201134546
month1_th0_tempmin_c -0.8
month1_th0_tempmin_f 30.6
month1_th0_tempmax_c 8.5
month1_th0_tempmax_f 47.3
month1_th0_temp_trend -1
month1_th0_dew_c -6.3
month1_th0_dew_f 20.7
month1_th0_dewmin_time 20111206090421
month1_th0_dewmax_time 20111203152548
month1_th0_dewmin_c -10.8
month1_th0_dewmin_f 12.6
month1_th0_dewmax_c 0.1
month1_th0_dewmax_f 32.2
month1_th0_dew_trend -1
month1_th0_heatindex_c 3.4
month1_th0_heatindex_f 38.0
month1_th0_heatindexmin_time 20111206034904
month1_th0_heatindexmax_time 20111201134546
month1_th0_heatindexmin_c -0.8
month1_th0_heatindexmin_f 30.6
month1_th0_heatindexmax_c 8.5
month1_th0_heatindexmax_f 47.3
month1_th0_heatindex_trend -1
month1_th0_humidex_c -0.0
month1_th0_humidex_f 31.9
month1_th0_humidexmin_time 20111206090421
month1_th0_humidexmax_time 20111201153806
month1_th0_humidexmin_c -4.7
month1_th0_humidexmin_f 23.5
month1_th0_humidexmax_c 5.5
month1_th0_humidexmax_f 41.9
month1_th0_humidex_trend -1
month1_th0_hum_rel 49.7
month1_th0_hummin_time 20111203112312
month1_th0_hummax_time 20111205124253
month1_th0_hummin_rel 39.0
month1_th0_hummax_rel 72.0
month1_th0_hum_trend -1
month1_t0_temp_c 22.1
month1_t0_temp_f 71.8
month1_t0_tempmin_time 20111204145023
month1_t0_tempmax_time 20111202021003
month1_t0_tempmin_c 19.5
month1_t0_tempmin_f 67.1
month1_t0_tempmax_c 23.9
month1_t0_tempmax_f 75.0
month1_t0_temp_trend 0
month1_t1_temp_c 3.3
month1_t1_temp_f 37.9
month1_t1_tempmin_time 20111206034938
month1_t1_tempmax_time 20111201134137
month1_t1_tempmin_c -1.3
month1_t1_tempmin_f 29.7
month1_t1_tempmax_c 8.5
month1_t1_tempmax_f 47.3
month1_t1_temp_trend -1
month1_t2_temp_c 18.9
month1_t2_temp_f 66.0
month1_t2_tempmin_time 20111205145711
month1_t2_tempmax_time 20111201012913
month1_t2_tempmin_c 15.9
month1_t2_tempmin_f 60.6
month1_t2_tempmax_c 21.5
month1_t2_tempmax_f 70.7
month1_t2_temp_trend 0
month1_data0_value_num 0.06
month1_data0_value_int 0
month1_data0_valuemin_num 0.00
month1_data0_valuemax_num 0.30
month1_data0_valuemin_int 0
month1_data0_valuemax_int 0
month1_data0_valuemin_time 20111201001917
month1_data0_valuemax_time 20111201160746
month1_data0_valuerise 79
month1_data0_valuefall 79
month1_data0_valuesum_num 15.00
month1_data0_valuesum_int 15
month1_data0_valuesumpermin_num 0.00
month1_data0_valuesumpermin_int 0
month1_data0_valuedeltasum_num 930.00
month1_data0_valuedeltasum_int 930
year1_utcdate 20111213035826
year1_localdate 20111213045826
year1_wind0_maxspeeddir_deg 247.5
year1_wind0_maxspeeddir_de WSW
year1_wind0_maxspeeddir_en WSW
year1_wind0_maindir_deg 225.0
year1_wind0_maindir_de SW
year1_wind0_maindir_en SW
year1_wind0_gustspeed_ms 2.7
year1_wind0_gustspeed_kmh 9.8
year1_wind0_gustspeed_mph 6.1
year1_wind0_gustspeed_kn 5.3
year1_wind0_gustspeed_bft 2.2
year1_wind0_gustspeedmin_time 20110101164637
year1_wind0_gustspeedmin_ms 0.0
year1_wind0_gustspeedmin_kmh 0.0
year1_wind0_gustspeedmin_mph 0.0
year1_wind0_gustspeedmin_kn 0.0
year1_wind0_gustspeedmin_bft 0.0
year1_wind0_gustspeedmax_time 20110207224134
year1_wind0_gustspeedmax_deg 240
year1_wind0_gustspeedmax_ms 26.8
year1_wind0_gustspeedmax_kmh 96.5
year1_wind0_gustspeedmax_mph 60.0
year1_wind0_gustspeedmax_kn 52.1
year1_wind0_gustspeedmax_bft 10.1
year1_wind0_speed_ms 2.7
year1_wind0_speed_kmh 9.8
year1_wind0_speed_mph 6.1
year1_wind0_speed_kn 5.3
year1_wind0_speed_bft 2.2
year1_wind0_speedmin_time 20110102082227
year1_wind0_speedmin_ms 0.0
year1_wind0_speedmin_kmh 0.0
year1_wind0_speedmin_mph 0.0
year1_wind0_speedmin_kn 0.0
year1_wind0_speedmin_bft 0.0
year1_wind0_speedmax_time 20110207222126
year1_wind0_speedmax_deg 246
year1_wind0_speedmax_ms 14.8
year1_wind0_speedmax_kmh 53.3
year1_wind0_speedmax_mph 33.1
year1_wind0_speedmax_kn 28.8
year1_wind0_speedmax_bft 6.8
year1_wind0_chill_c 7.5
year1_wind0_chillmin_time 20110223062342
year1_wind0_chillmax_time 20110627160644
year1_wind0_chillmin_c -14.1
year1_wind0_chillmax_c 26.4
year1_wind0_chill_f 45.6
year1_wind0_chillmin_f 6.6
year1_wind0_chillmax_f 79.5
year1_rain0_rate_mm 0.3
year1_rain0_rate_in 0.01
year1_rain0_ratemin_time 20110101000017
year1_rain0_ratemin_mm 0.0
year1_rain0_ratemin_in 0.00
year1_rain0_ratemax_time 20110619112414
year1_rain0_ratemax_mm 1440.0
year1_rain0_ratemax_in 56.69
year1_rain0_total_mm 985.20
year1_rain0_total_in 38.79
year1_rain0_total_time 20111206184335
year1_rain0_days 219
year1_thb0_temp_c 19.5
year1_thb0_temp_f 67.1
year1_thb0_tempmin_time 20110505090927
year1_thb0_tempmax_time 20110604194727
year1_thb0_tempmin_c 14.9
year1_thb0_tempmin_f 58.8
year1_thb0_tempmax_c 25.6
year1_thb0_tempmax_f 78.1
year1_thb0_temp_trend -1
year1_thb0_dew_c 8.9
year1_thb0_dew_f 48.1
year1_thb0_dewmin_time 20110221165126
year1_thb0_dewmax_time 20110730195328
year1_thb0_dewmin_c 0.3
year1_thb0_dewmin_f 32.5
year1_thb0_dewmax_c 17.4
year1_thb0_dewmax_f 63.3
year1_thb0_dew_trend -1
year1_thb0_heatindex_c 19.5
year1_thb0_heatindex_f 67.1
year1_thb0_heatindexmin_time 20110505090927
year1_thb0_heatindexmax_time 20110604194727
year1_thb0_heatindexmin_c 14.9
year1_thb0_heatindexmin_f 58.8
year1_thb0_heatindexmax_c 25.6
year1_thb0_heatindexmax_f 78.1
year1_thb0_heatindex_trend -1
year1_thb0_humidex_c 20.5
year1_thb0_humidex_f 68.8
year1_thb0_humidexmin_time 20110505094027
year1_thb0_humidexmax_time 20110730195328
year1_thb0_humidexmin_c 13.4
year1_thb0_humidexmin_f 56.1
year1_thb0_humidexmax_c 30.8
year1_thb0_humidexmax_f 87.4
year1_thb0_humidex_trend -1
year1_thb0_hum_rel 51.2
year1_thb0_hummin_time 20110221165026
year1_thb0_hummax_time 20110826160528
year1_thb0_hummin_rel 32.0
year1_thb0_hummax_rel 68.0
year1_thb0_hum_trend -1
year1_thb0_press_hpa 1003.9
year1_thb0_press_psi 14.56
year1_thb0_press_mmhg 752.9
year1_thb0_press_inhg 29.64
year1_thb0_pressmin_time 20111205011128
year1_thb0_pressmax_time 20110301230328
year1_thb0_pressmin_hpa 973.9
year1_thb0_pressmin_psi 14.12
year1_thb0_pressmin_mmhg 730.4
year1_thb0_pressmin_inhg 28.76
year1_thb0_pressmax_hpa 1033.1
year1_thb0_pressmax_psi 14.98
year1_thb0_pressmax_mmhg 774.8
year1_thb0_pressmax_inhg 30.51
year1_thb0_press_trend -1
year1_thb0_sealevel_hpa 1013.1
year1_thb0_sealevel_psi 14.69
year1_thb0_sealevel_mmhg 759.9
year1_thb0_sealevel_inhg 29.92
year1_thb0_sealevelmin_time 20111205011128
year1_thb0_sealevelmax_time 20110301230328
year1_thb0_sealevelmin_hpa 983.3
year1_thb0_sealevelmin_psi 14.26
year1_thb0_sealevelmin_mmhg 737.5
year1_thb0_sealevelmin_inhg 29.04
year1_thb0_sealevelmax_hpa 1042.5
year1_thb0_sealevelmax_psi 15.12
year1_thb0_sealevelmax_mmhg 781.9
year1_thb0_sealevelmax_inhg 30.78
year1_th0_temp_c 9.1
year1_th0_temp_f 48.4
year1_th0_tempmin_time 20110127083334
year1_th0_tempmax_time 20110627160644
year1_th0_tempmin_c -8.5
year1_th0_tempmin_f 16.7
year1_th0_tempmax_c 26.4
year1_th0_tempmax_f 79.5
year1_th0_temp_trend -1
year1_th0_dew_c 5.6
year1_th0_dew_f 42.2
year1_th0_dewmin_time 20111206090421
year1_th0_dewmax_time 20110826134342
year1_th0_dewmin_c -10.8
year1_th0_dewmin_f 12.6
year1_th0_dewmax_c 19.7
year1_th0_dewmax_f 67.5
year1_th0_dew_trend -1
year1_th0_heatindex_c 9.1
year1_th0_heatindex_f 48.4
year1_th0_heatindexmin_time 20110127083334
year1_th0_heatindexmax_time 20110627160644
year1_th0_heatindexmin_c -8.5
year1_th0_heatindexmin_f 16.7
year1_th0_heatindexmax_c 26.4
year1_th0_heatindexmax_f 79.5
year1_th0_heatindex_trend -1
year1_th0_humidex_c 9.1
year1_th0_humidex_f 48.3
year1_th0_humidexmin_time 20110127083334
year1_th0_humidexmax_time 20110731153758
year1_th0_humidexmin_c -12.4
year1_th0_humidexmin_f 9.7
year1_th0_humidexmax_c 32.5
year1_th0_humidexmax_f 90.5
year1_th0_humidex_trend -1
year1_th0_hum_rel 80.6
year1_th0_hummin_time 20110429170127
year1_th0_hummax_time 20110102013947
year1_th0_hummin_rel 29.0
year1_th0_hummax_rel 100.0
year1_th0_hum_trend -1
year1_t0_temp_c 21.0
year1_t0_temp_f 69.8
year1_t0_tempmin_time 20111128185801
year1_t0_tempmax_time 20111112141530
year1_t0_tempmin_c 0.2
year1_t0_tempmin_f 32.4
year1_t0_tempmax_c 85.0
year1_t0_tempmax_f 185.0
year1_t0_temp_trend 1
year1_t1_temp_c 12.4
year1_t1_temp_f 54.3
year1_t1_tempmin_time 20110327071305
year1_t1_tempmax_time 20110731153023
year1_t1_tempmin_c -5.4
year1_t1_tempmin_f 22.3
year1_t1_tempmax_c 30.1
year1_t1_tempmax_f 86.2
year1_t1_temp_trend -1
year1_t2_temp_c 19.2
year1_t2_temp_f 66.6
year1_t2_tempmin_time 20110321172550
year1_t2_tempmax_time 20110604152039
year1_t2_tempmin_c 1.8
year1_t2_tempmin_f 35.2
year1_t2_tempmax_c 34.0
year1_t2_tempmax_f 93.2
year1_t2_temp_trend 0
year1_data0_value_num 0.06
year1_data0_value_int 0
year1_data0_valuemin_num 0.00
year1_data0_valuemax_num 0.30
year1_data0_valuemin_int 0
year1_data0_valuemax_int 0
year1_data0_valuemin_time 20111128191135
year1_data0_valuemax_time 20111201160746
year1_data0_valuerise 111
year1_data0_valuefall 111
year1_data0_valuesum_num 20.40
year1_data0_valuesum_int 20
year1_data0_valuesumpermin_num 0.00
year1_data0_valuesumpermin_int 0
year1_data0_valuedeltasum_num 1270.00
year1_data0_valuedeltasum_int 1270
I fear that "meteohub log" on Log Files page will show error messages about bad data.
95% of issues with NSLU2 are worn out USB sticks which produce various kinds of malfunction.
BooX
Post by BooX »
Hi admin :)
Thank you for your reply.
It was a faulty usb-stick, but I was quite lucky that it was a quick fix.
1. Stopped all logging.
2. Used the clone function - which actually worked !
3. Booted with the new stick
4. Stopped all logging and did a data cleanup
5. Rebooted and waited for the data recomputation to finish
6. WORKING ! :D
I have ordered a couple of 4 Gb. "industrial grade" SLC CF-cards that I will try to use in a cardreader. I do have a cardreader that works with my linux sattelite reciever, I will do some tests with this reader.
Bo
