I'd like to read and log the amount of used electrical energy. From the sensor (energy meter) I get pulse-counts each minute.
Into which type of sensor should I log this value, for I could graph it as energy per time (rate) and/or total energy.
Further, how could I modify graphs then to display y-axis unit in kWh?...
Sensor type for energy metering
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
Hathor27
Re: Sensor type for energy metering
For anything non-standard use the "data" sensor type. That is totally 'generic'.Hathor27 wrote:I'd like to read and log the amount of used electrical energy. From the sensor (energy meter) I get pulse-counts each minute.
Your LED pulses are probably each 1Wh (at least that's pretty standard on UK meters).
I use "deltasum" with 1 hour 'buckets" to graph the number of Wh in an hour if I'm using Meteohub graphing.
If I'm using Meteoplug then I use the equivalent graphing feature, but in Meteoplug graph defeinitions you also have the opportunity for doing some maths.
Mosyly nowadays I use Meteoplug graphs...
That's goodskyewright wrote:I use "deltasum" with 1 hour 'buckets" to graph the number of Wh in an hour if I'm using Meteohub graphing.
And how do you build the sum of the individual pulses?
Best Regards
Hathor27
Hathor27
The data sensor that I use this with is an accumulating counter value.Hathor27 wrote:That's goodskyewright wrote:I use "deltasum" with 1 hour 'buckets" to graph the number of Wh in an hour if I'm using Meteohub graphing.![]()
If you are just delivering pulse counts, rather than a accumulating total, then maybe you could try "sum" instead of "deltasum"?
Thx - I will try it soon.skyewright wrote:If you are just delivering pulse counts, rather than a accumulating total, then maybe you could try "sum" instead of "deltasum"?
As I found by now, another approach would be the method I use for degree-days accumulation
(see viewtopic.php?f=16&t=8457&p=11241#p11241)
Best Regards
Hathor27
Hathor27
