Bug in virtual sensors command line?
Hathor27
Post by Hathor27 »
If I hit a command line for virtual sensors, such as
awk '{if ($3<150) {printf "%d", 200-$3} else print "0"}'
and press save, Meteohub takes this command string and works fine with it.
But if I want to edit this command line, I just can reach the first 26 characters of it
Boris, could please enlarge that input field?
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
Re: Bug in virtual sensors command line?
Hard to believe that you cant reach the other letters. Did you try moving the cursor with the arrow keys. The field does scroll then, when I do remember right.
Hathor27
Post by Hathor27 »
admin wrote:Hard to believe that you cant reach the other letters. Did you try moving the cursor with the arrow keys. The field does scroll then, when I do remember right.
I'm sorry to say that, Boris: I tried it several times, scrolled left and right - no chance at all :?
Best Regards
Hathor27
Post by skyewright »
Hathor27 wrote:Boris, could please enlarge that input field?
If I look at the html source of the form it shows maxlength="458" for that field!
By curious coincidence my virtual command lines are exactly 26 characters long, so I can't test for the behaviour you have seen without making a change that would invoke a (very long) recompute.
Could it be a browser issue? Which browser are you using? Have you tried looking at the form in a different browser.
Hathor27
Post by Hathor27 »
skyewright wrote:Could it be a browser issue? Which browser are you using? Have you tried looking at the form in a different browser.
I'm using the good old standard: Internet Explorer 8
Uses anybody virtual command lines exceeding 26 characters?
Best Regards
Hathor27
d_l
Post by d_l »
I've a command line of 158 characters that I can scroll to the end. This is on 4.6t. I doubt that Boris reduced that field for newer versions. Scrolling using FF 4.0.1. I don't update that frequently unless there is a good reason.
Hathor27
Post by Hathor27 »
d_l wrote:I've a command line of 158 characters that I can scroll to the end. This is on 4.6t. I doubt that Boris reduced that field for newer versions. Scrolling using FF 4.0.1. I don't update that frequently unless there is a good reason.
I recognized the problem in v4.8i, and it persists in v4.9 - good idea not to update that frequently...
Best Regards
Hathor27
I cannot confirm the error. Is it just an IE8 issue? Did you try other browsers?
Hathor27
Post by Hathor27 »
admin wrote:I cannot confirm the error. Is it just an IE8 issue? Did you try other browsers?
No I didn't another browser - I only run on IE8 (standard?).
Is there an other way to test it? Are you able to test it on IE8?
Best Regards
Hathor27
