Bug in virtual sensors command line?
Posted: Mon Jan 09, 2012 1:57 pm
by Hathor27
If I hit a command line for virtual sensors, such as
awk '{if ($3<150) {printf "%d", 200-$3} else print "0"}'
and press save, Meteohub takes this command string and works fine with it.
But if I want to edit this command line, I just can reach the first 26 characters of it
Boris, could please enlarge that input field?
Re: Bug in virtual sensors command line?
Posted: Tue Jan 10, 2012 1:29 am
Hard to believe that you cant reach the other letters. Did you try moving the cursor with the arrow keys. The field does scroll then, when I do remember right.
Posted: Tue Jan 10, 2012 1:44 am
by Hathor27
admin wrote:Hard to believe that you cant reach the other letters. Did you try moving the cursor with the arrow keys. The field does scroll then, when I do remember right.
I'm sorry to say that, Boris: I tried it several times, scrolled left and right - no chance at all :?
Posted: Tue Jan 10, 2012 1:02 pm
by skyewright
Hathor27 wrote:Boris, could please enlarge that input field?
If I look at the html source of the form it shows maxlength="458" for that field!
By curious coincidence my virtual command lines are exactly 26 characters long, so I can't test for the behaviour you have seen without making a change that would invoke a (very long) recompute.
Could it be a browser issue? Which browser are you using? Have you tried looking at the form in a different browser.
Posted: Tue Jan 10, 2012 10:34 pm
by Hathor27
skyewright wrote:Could it be a browser issue? Which browser are you using? Have you tried looking at the form in a different browser.
I'm using the good old standard: Internet Explorer 8
Uses anybody virtual command lines exceeding 26 characters?
Posted: Wed Jan 11, 2012 3:57 am
by d_l
I've a command line of 158 characters that I can scroll to the end. This is on 4.6t. I doubt that Boris reduced that field for newer versions. Scrolling using FF 4.0.1. I don't update that frequently unless there is a good reason.
Posted: Mon Jan 23, 2012 12:44 am
by Hathor27
d_l wrote:I've a command line of 158 characters that I can scroll to the end. This is on 4.6t. I doubt that Boris reduced that field for newer versions. Scrolling using FF 4.0.1. I don't update that frequently unless there is a good reason.
I recognized the problem in v4.8i, and it persists in v4.9 - good idea not to update that frequently...
Posted: Mon Jan 23, 2012 1:13 am
I cannot confirm the error. Is it just an IE8 issue? Did you try other browsers?
Posted: Mon Jan 23, 2012 2:05 pm
by Hathor27
admin wrote:I cannot confirm the error. Is it just an IE8 issue? Did you try other browsers?
No I didn't another browser - I only run on IE8 (standard?).
Is there an other way to test it? Are you able to test it on IE8?
