Update failed - tried both web and file...
BooX
Post by BooX »
Hi
I'm trying to updage my Meteohub 4.6i running on a NSLU2 to the current version.
Pressing the "Software Update (auto)" button results in "error downloading v4.9", I have tried several times even after a reboot and finished data recomptutaion but still the same result.
I've also tried to download the file and do a manual update with with almost the same result. I don't get no errror messages but just a "can´t show this page" when IE refreshes.
I've looked thrue the logs and can't see anything related to my various attempt.
Any suggestions ?
Thank you.
Bo :o)
BooX
Re: Update failed - tried both web and file...
Post by BooX »
Don't know if the disk usage has something to do with the problem ?
System stays at 100% even after a reboot :?:
StorageSwap: 0MB of 126MB used (0%)
System: 402MB of 402MB used (100%)
Data: 671MB of 3303MB used (20%)
Bo
that is a good explanation. Looks like a file system error.
when you give me access to ports 22 and 7777 I can try to fix it.
Procedure is too complicated to be described here.
Anyway, you should look for a new USB stick.
BooX
Post by BooX »
Hi Borris
Sounds very good, I've send you my details in a PM.
"USB-stick" is brand new, I've cloned the old one the a brand new SLC-CF-card, maybe something went wrong in that process ?
Bo
yes, will check....
cloning of the stick did fail a bit. I found a filled up /mnt directory.
cleared that and installed version 4.9. Should be ok now...
BooX
Post by BooX »
admin wrote:cloning of the stick did fail a bit. I found a filled up /mnt directory.
Woow !
That´s just great, it just made my saturday perfect :D
Thank you very much :)
Bo
