WeatherLink to Meteohub?
Brendianer
Post by Brendianer »
Dear all
I actually moving from WeatherLink to Metoehub. Is it possible to convert old data from WeatherLink to use them with Meteohub?
Regards Brendianer
Re: WeatherLink to Meteohub?
Meteohub itself does not provide a converter.
Did someone here constructed a tool himself? As Meteohub raw data format is described in the manual, this could be done by someone with reasonable programming skill.
EmjayNet
Post by EmjayNet »
I created a web app in VB that took WD data and converted it to MH raw.
I only did it as an excerise, so did not go on to use it much or test in anger to offer other people.
It is time consuming to do, but it can be done!
Good Luck
Mark
Marcel-EDDF
Post by Marcel-EDDF »
Hi Meteohub Forum,
as I use an PWS Davis VUE since 05/2017 I would like also to Switch over to meteohub.
Is there a Chance to convert / imoprt my archived datas to the meteohub?
Best regards
Marcel
