Some gnuplot commands
najbo
Post by najbo »
hi !
Some interesting samples are provided on the gnuplot homepage, available here : http://azog.bioinformatics.vt.edu:49280
and here : http://azog.bioinformatics.vt.edu:49280/demo
patonnet74
Re:Some gnuplot commands
Post by patonnet74 »
I've been trying to work some out, and as posted on another thread had used the following command to change a few things on my last 24 hour graph:
set format x \"%H:%M\"|set mxtics 4|set grid nomxtics|set format y \"%.0f\"|set ylabel \"Degrees Centigrade\"|set lmargin 10
Broken down
only show hours and minutes on x axis eg 21:00
|set mxtics 4
show four minor tics per major tic (default shows a major tic every 4 hours on mine, so now a minor tic every hour)
|set grid nomxtics|
don't show a grid line for the minor tics, only the major ones
Show my y axis in whole numbers only
Label the Y axis with Degrees Centigrade
|set lmargin 10
This aligns the left margin, and I use it in each graph to make sure they are all aligned
Now I wanted to play with the tics on the yaxis and added:
set ytics 10
But this simply seems to reset the graph back to defaults. Anyone know why?
A beginner with GNU Plot so any other help would be appreciated.
Anyone got any other examples of formatting they've used on Meteohub?
Cheers,
Alan
binbags
Post by binbags »
Hi Alan
Yes I would also like to delve further into gnuplot, so to speak.
I have printed off the gnu manual, but I think my headache just turned into a migrane. It would be nice for those in the know to teach us few who do not how to use the format command line:unsure:
Meanwhile I will keep on reading.
alan
nanks
Post by nanks »
Here's a \"Format cmd\" I worked out to provide
filled in bargraphs that I use for my rainfall
graphs
set boxwidth 0.75 relative|set style fill solid 1.00 border -1
The boxwidth part sets the width of the bar to 75%
of normal, that is it leaves a gap between the bars.
The fill part does the solid fill for the bar
and the border part puts a fine border around the bar
to accentuate it.
Peter
