System log messages
gordonb
System log messages
Post by gordonb »
I've recently set up an iConnect box as a Meteohub and by and large it's working well but I was looking at the system log today and found the following repeated more or less the same several times over several days;
cat: /data/weather/20*/raw: No such file or directory
expr: division by zero
2011-12-30T09:35:56.665789+00:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2011-12-30T09:35:56.665843+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2011-12-30T09:35:56.665861+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2011-12-30T09:35:56.665876+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2012-01-01T06:25:02.709832+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-01-01T06:25:02.709849+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-01-01T06:25:02.709864+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
Is this potentially a problem and if so can anyone tell me how to resolve it?
Cheers
Gordon
JohnR
Re: System log messages
Post by JohnR »
Same for me on my iconnect.
No idea if this is a problem or not.
John
2012-01-13T21:10:32.768511+00:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-01-13T21:10:32.768565+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-01-13T21:10:32.768582+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-01-13T21:10:32.768597+00:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
I have forced the log deamon to work in a compatibility mode, so that SW does not need to be changed too much between all the different Meteohub HW platforms (from NSLU2 to ALIX to Sheeva/iConnect). You can completely ignore these messages.
