My Alix3D is sick...
We had a power outage. After the power was restored the Alix came up with errors on /dev/hda3 which is /data
I connected a keyboard and ran fsck manually. Lost the data, but found some files (graphs etc) in /data/Lost+Found/
Recreated the /data disrectories and meteo happily started logging and updating wunderground again.
This morning:
Buffer I/O error on device hda3, logical block 3958107115
lost page write due to I/O error on hda3
Aborting journal on device hda3.
ext3_abort called.
EXT3-fs error (device hda3): ext3_journal_start_sb: Detected aborted journal
Remounting filesystem read-only
attempt to access beyond end of device
hda1: rw=1, want=18190449728, limit=1574307
Buffer I/O error on device hda1, logical block 2273806215
lost page write due to I/O error on hda1
Aborting journal on device hda1.
ext3_abort called.
EXT3-fs error (device hda1): ext3_journal_start_sb: Detected aborted journal
alarm[9142]: segfault at 00000046 eip b7ebc66d esp bfa06b70 error 4Doesn't look good. I can log in, and the wunderground logging is running ok, but the meteohub web interface says:
Error file open /home/meteohub/meteohub.confI've only get a spare slow Kingston camera CF - probably MLC, have ordered a new SLC card, but I somehow doubt that it will arrive in time.
Do you think this CF is broken or will a blank and re-install on this CF solve my problems?
Cheers,
Michael
