Has anyone a good solution to convert the Meteohub datafiles to Weather Display?
The export function in the Meteohub software is no option because a lot of data is missing.
I also tested this option:
http://www.weather-watch.com/smf/index. ... ic=32544.0
But after a couple of hours running WD goes on tilt.
regards
Geert
Convert datafiles Meteohub -> Weather Display
Re: Convert datafiles Meteohub -> Weather Display
Yes I reported the export issue a couple of weeks ago but it is not fixed yet!
The only way round the WD crash thing is;
setup your import date in WD INI file and run.
When WD crashes, close the running programs with task manager.
Look in log file directory for the file of the month you were importing.
Load file in text editor and go to end to get the date of last import at the crash.
Open WD INI again and change Davis download date to the new date at crash.
Start all over again, until crash and repeat.
Not ideal I know but it's all you can do until either Brian fixes WD or Boris fixes the export features!
Hope it helps
Mark
Hope it helps
Mark
- AenG
- Senior Boarder
That is indeed a solution but I have three years of data files. It takes me weeks this way.
The export option in the Meteohub software works very fast but does not take all the data.
Perhaps Boris could explain why not all data is converted.
