I have modified a THGR810 to sense light instead of temperature.
How do I make a readout showing % instead of degrees on the side of the graph??
Lux-meter using a temp sensor (WMR200)
Re: Lux-meter using a temp sensor (WMR200)
This you could try: Create a virtual sol sensor eg. "sol0" and trigger your modified THGR810. Under 'conversion': sensdiffmaster 1 300". After this you can finetune this virtual sensor under 'settings'.Hubb-er wrote:I have modified a THGR810 to sense light instead of temperature.
Good luck.
