Lux-meter using a temp sensor (WMR200)
Posted: Wed Jan 25, 2012 7:35 pm
by Hubb-er
I have modified a THGR810 to sense light instead of temperature.
How do I make a readout showing % instead of degrees on the side of the graph??
Re: Lux-meter using a temp sensor (WMR200)
Posted: Thu Jan 26, 2012 3:35 am
by idociko
Hubb-er wrote:I have modified a THGR810 to sense light instead of temperature.
This you could try: Create a virtual sol sensor eg. "sol0" and trigger your modified THGR810. Under 'conversion': sensdiffmaster 1 300". After this you can finetune this virtual sensor under 'settings'.
Good luck.
