Activation not possible
Tom1966
Post by Tom1966 »
I just purchased the activation code for the iConnect and updated to the new version 4.9. The result is, that the activation code is not accepted (no error message) and I have now gigantic 183 days left in the demoversion (...before, I was down to one day).
Can you check? I will send you data you need on request.
Thank you
Tom
Re: Activation not possible
Please send system ID (on system info page) and activation code (on maintenance page) to info(at)meteohub.de.
It is for sure a setup error. Activation per se works flawless on hundreds of systems.
Tom1966
Post by Tom1966 »
I will do in a few minutes. Thanks for your help in advance.
Kind Regards
Tom
Fixed... (MAC instead of system ID used for activation code generation).
