Recording Evapotranspiration Problem
Sperber68
Post by Sperber68 »
Hello Weather community, my Davis pro with the weatherboxx now in operation since 02:02:12.
Everything runs with no problems except for the evapotranspiration.
The console has different values ​​than those in the all-sensor.xml of meteohub!
Currently I have totals on the console of 7.1 mm per month, and year.
The daily values ​​are added together to brave the total values​​.
Here, the current exodus of all-sensor.xml 15:02:12
<data timeframe="actual">
<item sensor="sol0" cat="evotranspiration" unit="inch">0.07</item>
<item sensor="sol0" cat="evotranspiration" unit="mm">1.8</item>
<data timeframe="alltime">
<item sensor="sol0" cat="et" unit="mm">2.1</item>
<item sensor="sol0" cat="et" unit="in">0.1</item>
<data timeframe="day1">
<item sensor="sol0" cat="et" unit="mm">0.5</item>
<item sensor="sol0" cat="et" unit="in">0.0</item>
<data timeframe="hour1">
<item sensor="sol0" cat="et" unit="mm">1.7</item>
<data timeframe="last15m">
<item sensor="sol0" cat="et" unit="mm">1.5</item>
<data timeframe="last24h">
<data timeframe="last60m">
<item sensor="sol0" cat="et" unit="mm">1.4</item>
<data timeframe="month1">
<data timeframe="year1">
The 7.1 mm are not available and worth the month and year are now for 1 week to 2.1 mm.
The actual values ​​are consistent with the Daily values ​​of the console and not worth day1 morning start and end with 0.3 to 0 clock always at 2.1 mm.
Since the worm is inside :roll:
Because one has an idea where there is the problem?
Thank you!
wfpost
Re: Recording Evapotranspiration Problem
Post by wfpost »
a bug, already reported in other threads.
Unfortunately Boris is very reluctant on fixing a couple of bugs having reported over and over again.
Don´t know why? ... because bugs that lead to wrong weather data should be taken care and fixed also ...
Sperber68
Post by Sperber68 »
thx... grrr a bug not a worm :(
Sorry i dont find this problem in a other thread.
Please Boris help us !!! i cant live with a not right evopo.... i am a farmer ;)
Sperber68
Post by Sperber68 »
Have solved the problem of the current data !
Simply use with php the wrong value of meteohub xml by a factor of 0.2 ... multiplied :)
Fits right in!
The monthly and yearly values ​​must do manually, since meteohub not add correctly the daily values​​ :roll:
