Page 1 of 2
OWL CM119 and rfxsensor not show in meteohub
Posted: Wed Mar 07, 2012 3:18 pm
by jperillo
Hello all,
I'm a new user of Meteohub on sheeva and I use the new rfxcom usb with some oregon, owl 119 and rfxsensor sensors's.
I see in meteohub all my oregon sensor's but no the OWL and rfxsensors. Is something special to do to see it, or isn't possible to add it on my Meteohub system ?
Thank you
Re: OWL CM119 and rfxsensor not show in meteohub
Posted: Thu Mar 08, 2012 8:55 am
by b_weijenberg
The latest RFXtrx433 firmware version 24 has an improvement for CM119 decoding. See the RFXCOM download page.
For the RFXSensor you need to enable the X10 protocol in the RFXtrx433.
Disable all protocols not used to improve the receive sensitivity of the RFXtrx433!!
Posted: Thu Mar 08, 2012 5:49 pm
by jperillo
Thank you for your answer. I disable all protocol exept X10 and Oregon, in rfxmgr I see now the OWL and rfxsensor information ( I never see that before your explaination :) ) but in meteohub I continue to see in log :
logger (08.03.2012 16:33:46): station 0 (RFXTRX 433MHz), firmware version: 2.4
logger (08.03.2012 16:33:46): station 0 (RFXTRX 433MHz), frequency: 433.92 MHz
logger (08.03.2012 16:33:46): station 0 (RFXTRX 433MHz), enabled protocols: La Crosse, Hideki, Oregon Scientific
and I cannot see the OWL and Rfxsensor on the sensor list ( but I receive two new sensors coming from nowhere ... )
any idea ?
Posted: Fri Mar 09, 2012 8:55 am
Ahhh, you refer to the new rfxtrx from rfxcom. Implementation of that new device is not complete in Meteohub right now.
But I would like to expand this. Do you have a chance to provide me access to your Meteohub on ports 22 and 7777 in order to do some testing over the weekend?
Posted: Fri Mar 09, 2012 10:00 am
by jperillo
both port are open.
I send to you by mp the ip address.
Thank you !
Posted: Fri Mar 09, 2012 7:40 pm
I tried a bit, but I can't find data beside some undecoded lacrosse data coming in...
Do I still have to activate other vendor settings to get these? I think I have enabled more or
less every kind of transmission.
2012.03.09 18:21:29 log file cleared by user
logger (09.03.2012 18:32:36): data logger (version 4.9f, build 1001) started.
logger (09.03.2012 18:32:36): connect station 0 (RFXTRX 433MHz via USB serial).
logger (09.03.2012 18:32:36): station 0 (RFXTRX 433MHz), firmware version: 2.4
logger (09.03.2012 18:32:36): station 0 (RFXTRX 433MHz), frequency: 433.92 MHz
logger (09.03.2012 18:32:36): station 0 (RFXTRX 433MHz), enabled protocols: La Crosse, Hideki, LightwaveRF, Metrik, Oregon Scientific, HomeEasy EU, AC, ARC, X10
logger (09.03.2012 18:33:42): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 11 30 93 d2 5e 14 2e be
logger (09.03.2012 18:33:43): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 12 30 94 d2 5e 36 9c 96
logger (09.03.2012 18:33:43): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 13 30 93 d2 5e 14 2e be
logger (09.03.2012 18:35:50): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 36 30 90 d2 7e 36 8c 93
logger (09.03.2012 18:35:51): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 37 30 95 d2 7e 45 db ad
logger (09.03.2012 18:35:51): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 38 30 92 d2 7e 65 b9 a8
logger (09.03.2012 18:35:52): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 39 30 95 d2 7e 45 db ad
logger (09.03.2012 18:35:52): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 3a 30 93 d2 7e 19 3e 61
logger (09.03.2012 18:37:59): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 63 30 93 d2 5e 12 4e d0
logger (09.03.2012 18:38:00): station 0 (RFXTRX 433MHz): unknown lacrosse sensor: 10: 03 04 64 30 95 d2 5e 45 db ab
Posted: Fri Mar 09, 2012 8:24 pm
please make sure to use latest firmware (http://www.rfxcom.com/downloads.htm)
Posted: Fri Mar 09, 2012 8:26 pm
by jperillo
I use only oregon sensors, RFXsensors and OWL CM119. I have the latest firmware installed yersterday.
Could you please enable only Oregon and X10 for rfxtrx please ?
Thank you for your support
Posted: Fri Mar 09, 2012 8:27 pm
by jperillo
I see my rfxsensors on the log :)
logger (09.03.2012 18:40:08): station 0 (RFXTRX 433MHz): unknown rfxtrx sensor: 14: 59 0a 03 04 88 30 95 d2 5e 45 db ab 0a 03
Posted: Fri Mar 09, 2012 8:35 pm
jperillo wrote:I see my rfxsensors on the log :)
nope, this is just a misaligned 03 04 88 30 95 d2 5e 45 db ab sequence. I change code to supress that.
Oregon an X10 is enabled. Why to enable these ONLY?
Posted: Fri Mar 09, 2012 8:39 pm
by jperillo
I use only Oregon sensors and Rfxsensor that use x10. I see on rfxcom site that less you have enabled protocol and better is the reception, ( I have no idea if is true ).
OWL Cm119 use Oregon protocol to communicate but at this time I don't see it :(
Posted: Sat Mar 10, 2012 11:00 am
Looks like Meteohub had finally picked up some RFXsensors. But just Temperature sensors, is that correct?
Posted: Sat Mar 10, 2012 2:24 pm
by jperillo
Yes is that correct ! Wonderfull ! Can meteohub see my power consumption via the cm119 ?
Did you enable only oregon and x10 ?
Posted: Sat Mar 10, 2012 2:59 pm
yes, I did setup oregon and X10. could your please connect the rfxtrx to your PC and log some cm119 data with it?
Please post the bytes here, so that I can see how to squeeze this out via Meteohub.
Posted: Sat Mar 10, 2012 3:45 pm
by jperillo
Is that do you need ?
115A01063DE200000002C400002A70A90859
Packettype = ENERGY
subtype = ELEC2 - OWL CM119, CM160
Sequence nbr = 6
ID = 15842
Count = 0
Instant usage = 708 Watt
total usage = 3183435,90889988 Wh
Signal level = 5
Battery = OK
