Höchsttemperatur
fuxe13
Höchsttemperatur
Post by fuxe13 »
Hallo Zusammen!
Kann mir jemand sagen, wo die Obergrenze der Temperatur ist? Ist sie noch auf 60° begrenzt oder gehts schon bis 70° ??
Danke im Vorraus
Walter
fuxe13
Re: Höchsttemperatur
Post by fuxe13 »
Kennst den NIEMAND die Höchsttemperatur, die Meteohub Anzeigen kann??? :shock:
YJB
Post by YJB »
A little search on this forum would have helped:
viewtopic.php?f=9&t=7485&hilit=maximum+temperature
Skye has been reporting 90+ degrees, so you're not even close. To be honest, most likely your sensor will be the limitation (assuming you are using a standard weather station).
fuxe13
Post by fuxe13 »
Hello!
Thank you! Had tried the search but were probably the wrong concepts :(
I once had what degree are 60 °, so I'm in demand ....
Billy
Post by Billy »
Due to my request regarding the "Kollektortemperatur" of a heating system it was stepped up by Boris to 130°C.
Billy
fuxe13
Post by fuxe13 »
ok, thank you! that's nice.
Thank at all!
