Delete records issue?
D70
Post by D70 »
My Weather Station was wrongly reporting very low pressure from 10/01/2012 to 22/01/2012. I had deleted the sensor data through the "Inspect Data" option. After I pressed delete I got the "*" mark on all records. Then I ran "Aggregated Weather Data" option. After that I'm still getting the wrong pressure values on the graphs and it is also reporting that low values to Meteoclimatic (*YLBR=629.0). How can I permanently delete the records?
Re: Delete records issue?
after recomputation has run through the data marked as deleted are no longer taken into account. the error must be somewhere else.
1) recomputation has not finished yet
2) not all data marked for deletion
D70
Post by D70 »
Meanwihle I edited the raw file and deleted the lines.
Thanks anyway.
