Full backup issue on DC01?
ZebraWetter
Location: Duisburg/northrhine-westfalia/germany/earth/sol system
Post by ZebraWetter »
Hi there!
When I try to start a full backup on my DC01 the message "backup already running." appears in the meteohub.log.
The message appears although there is surely no backup process running.
Starting a full backup in a ssh session on the command line is possible. (script "fullbackup")
The command "ps ax | grep fullbackup | grep -v grep | wc -l" results in 0 or - while running the backup - in 1.
Andre
edit: v4.9g (Build 1043) - same problem
k76
Re: Full backup issue on DC01?
Post by k76 »
it's the same problem on my Meteohub (4.9i on DC01). When clicking the backup button meteohub says
Backup to file "/public/meteohub.backup" successfully started.
An entry in the log file will indicate when creation of back file has been completed.
Meteohub log says:
Tue Jun 5 22:29:10 CEST 2012: backup already running.
But there is no other backup running.
Does anyone already know a solution?
regards
Kai
Yes, it is a bug on DC01. Will be fixed with next update.
