Sheeva Plug new box ethernet port is not working
Holsteinson
Post by Holsteinson »
For some reason I just got a new Sheeva Plug box and I have connected to the network and its ethernet is working while powering up but then its 2 yellow or green leds are off and I cant find it with the IP scanner (the status lights are on solid
If I unplug the power cord the Sheeva Plug will start and get both status lights solid and the ethernet led work for about 30 seconds and the turn off HELP
Holsteinson
Re: Sheeva Plug new box ethernet port is not working
I unplug the power cord last night of the Sheeva Plug and left it overnight and replug it this morning the 2 status lights are red and blue solid and got the yellow-green lights of the ethernet port flashed for about 1 minute during powering up and then no more... what is wrong here? HELP!
When setting up a SheevaPlug to become a Meteohub you have to follow these instructions: http://wiki.meteohub.de/Setup_SheevaPlug
Without telling us at what step you did fail, no one will be able to help you.
Holsteinson
Hola Boris I bought it preconfigured as Weather2Hub from Ambient Weather I just followed the instructions insert SD, connect the ethernet cable to router and connect the power cord to wall plug. Waited for lights to become solid (red/blue) and use the IP Scan software and it is not showing listed nor the ethernet port yellow-green led lights are on.... HELP
Please try "reading the Blinks" from the instructions linked above to get the IP.
