Help: Very high wind speed rates on Dashboard
panos1981
Post by panos1981 »
I use the LaCrosse WS2355 with Meteohub. On the Dashboard the wind speed rates are very high, while in the graphs the wind speed rates are right. I thought that maybe the connection between the base station and Meteohub generates the problem. So I changed the connection from USBserial to serial but there was no result. Also I connected the station to the other USB port, but again the same problem. What else can I try to handle this situation? I would really be happy if you helped me, because everything is already to upload my station to my website, except the wind speed rates on Dashboard!
Thank you
Peter
