Warnings in system log
wochips
Post by wochips »
I keep getting the following warning messages in the system log but don't know how important they are or how to implement the suggestions, any advice would be appreciated.
2012.05.28 17:02:21 log file cleared by user
2012-05-29T01:02:41.171513+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-05-29T01:02:41.171570+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-05-29T01:02:41.171588+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-05-29T01:02:41.171603+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2012-05-30T01:02:41.301436+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2012-05-30T01:02:41.301491+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-05-30T01:02:41.301508+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-05-30T01:02:41.301523+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
WMR88 UV
iConnect
Re: Warnings in system log
just ignore. it is about using the message logging daemon in an outdated way, which is needed to keep Meteohub version identical over all installations.
wochips
Post by wochips »
Thank you, good to know it is not a problem.
WMR88 UV
iConnect
