RFXCOM and Esic WT450H on iConnect
This is intended for discussion and information about the rfxcom receiver module
vorsteh1
Post by vorsteh1 »
Hi.
I just bought an iConnect and a RFXcom transceiver and installed Meteohub. The iConnect works great together with the Oregon sensors that I have. But I also have some ESIC WT450H sensor that is compatible with the Rfxcom transceiver. When I test it on a pc I can see that I recieve the signals from the WT450 on the correct channel. But when the Rfxcom is connected to the meteohub there is no signals going trough. Does anyone know where to start to solve this problem?
Vorsteh
vorsteh1
Re: RFXCOM and Esic WT450H on iConnect
Post by vorsteh1 »
My mistake. When I decided to get the iConnect with Meteohub and RFXTRX it looked like I could use many different sensors. But even though the RFXtrx can handle the signals, there are limitations on the Meteohub side. Hopefully more sensors will be added to the compatibillity list and not be limited to only OS sensors.
Could you please post examples of the datasets the RFXTRX prints out for the WT450H. I might be able to include this into one of the next updates. What station type must be enabled to have the WT450H signals coming in?
