RFXTRX - problems with THWR800
This is intended for discussion and information about the rfxcom receiver module
SMB_weather
Post by SMB_weather »
I have a THWR800 being read with RFXCOM RFXTRX. The sensor and its data appear on the sensor page but data is not being saved. Does anyone know how to solve? My hardware is iConnect with meteohub 4.9j.
SMB Weather
South Mission Beach & Townsville
North Queensland, Australia
http://www.4852q.info
iConnect, RFXCOM, WS2081 & ENVI
Re: RFXTRX - problems with THWR800
you need to assign an id for it on "sensors" page.
does "meteohub log" report any errors?
SMB_weather
Hi Boris,
The sensor has been assigned as follows:
Station 3 (RFXTRX 433MHz): RFXCOM
THWR800 26:1 t3 37sec 20.8°C
The log shows some unknown lacrosse messages, these are not my devices:
logger (16.06.2012 21:38:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 00 27 aa 00 00 01 ac
logger (16.06.2012 21:40:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 01 27 aa 00 00 01 ac
logger (16.06.2012 21:42:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 02 27 aa 00 00 01 ac
logger (16.06.2012 21:44:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 03 27 aa 00 00 01 ac
logger (16.06.2012 21:45:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 04 27 aa 00 00 01 ac
logger (16.06.2012 21:46:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 05 27 aa 00 00 01 ac
logger (16.06.2012 21:47:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 06 27 aa 00 00 01 ac
logger (16.06.2012 21:48:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 07 27 aa 00 00 01 ac
logger (16.06.2012 21:49:25): station 3 (RFXTRX 433MHz): unknown lacrosse sensor: 9: 03 04 08 27 aa 00 00 01 ac
There are also the following messages, repeated several times each day:
logger (16.06.2012 21:34:00): no signal from station 3 (RFXTRX 433MHz) for 450 seconds, station to be restarted.
logger (16.06.2012 21:34:00): disconnect station 3 (RFXTRX 433MHz).
logger (16.06.2012 21:34:34): connect station 3 (RFXTRX 433MHz via USB serial)
But no data is saved.
SMB Weather
Could you please open ports 22 and 7777 on your router and forward these to the LAN IP of your Meteohub?
Please send the WAN IP to "info(at)meteohub.de", so that I can check on your rig.
SMB_weather
Hi Boris,
I have relocated the RFXTRX module and the communications with the THWR800 are now stable. I upgraded Meteohub to 4.9l but the data is still not being saved. Can you help?
SMB Weather
did you apply an id at "sensors" page?
SMB_weather
Hi Boris,
Yes ID assigned as follows:
Station 3 (RFXTRX 433MHz): RFXCOM_RFXTRX
THWR800 109:3 t10 15 sec 21.7°C
But still no data being saved.
SMB Weather
could you please give me acces by browsing to "http://ip-of-your-meteohub/cgi-bin/help.cgi".
SMB_weather
Hi Boris,
I have opened ports 22 + 7777 and http on another port. I will email you the ip address and port.
SMB Weather
some findings:
1) when you have more than one USB serial device you shouldn't use the enumerated "/dev/ttyUSBx" device names,
as the enumeration of these devices is more or less random on reboot. I changed that to device names which reference
physical ports on your meteohub, like "/dev/ttyMH112".
2) log files indicate with messages like the ones attached, that the storage media is somehoe corrupted.
I did a clean of 201208 raw data by correxponding functions on "inspect data" page. Hopefully,
this will fix it ongoing.
loggereval (13.08.2012 18:26:49): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
loggereval (13.08.2012 18:27:15): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
loggereval (13.08.2012 18:27:26): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
loggereval (13.08.2012 18:28:14): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
loggereval (13.08.2012 18:29:11): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
loggereval (13.08.2012 18:30:17): illegal data record in line 523265 while reading from file /data/weather/201208/raw: 2012080411u724 data22 59700
This error also blocks computation of data, so some values might not appear on graphs etc as expected.
3) Normally Oregon sensors send data packets twice (with a very short delay inbetween), but your THWR800 sensor does not.
I changed evaluation logic to handle this. Is it a "regular" Oregon THWR800 or something just sending similar data?
Please test if the system does now operate as expected. I will make the changes to be part of 4.9m coming soon...
SMB_weather
Hi Boris,
Thank-you for your advice about the physical port names, I will do these names in the future.
I have tested the system this morning and the data is being saved! I will upgrade to meteohub 4.9m tonight and build a new SLC drive.
The THWR800 is "out of the box" from Oregon Scientific but I noticed is is stamped "V3". I googled this morning and found some info at http://jeelabs.net/projects/11/wiki/Dec ... 2_protocol:
The major differences beween the V2 and V3 protocol are:
•the packet is sent twice
•the preamble is based on long pulses and the start bit is a short bit.
•each bit of data is serialized twice but the second is logically inverted.
So, it sounds like Oregon Scientific V3 may only send data once.
SMB Weather
I got information from Bert from RFXCOM, that second packet is generally stripped by TRXRFX.
New version 4.9m should now handle that corectly for all Oregon sensors.
