my sheevaplug (which i tought had a problem with the SD card) does not boot anymore.
The blue LED does not light, just the gree one and the LEDS at the ethernet connector.
When i connect via linux and USB and try to connect it says that there is no sheeva plug connected....
Any ideas ???
Thanks Christian
Flash by Linux and via MAC says : no sheeva connected
richardkimble
- Fresh Boarder
richardkimble
- Fresh Boarder
Re: Flash by Linux and via MAC says : no sheeva connected
...I found out, that the PSU just has 4,4 Volt, i guess that is the problem and so i ordered a new PSU in the UK.
richardkimble
- Fresh Boarder
...just for the record or the search-engine....
i bought a new PSU from NEWIT, the sheevaplug started and bootet without any problem, and there even were no data losses....
thanks for the fast reply from NEWIT in GB.
Greetings
Christian
Greetings
Christian
When i connect via linux and USB and try to connect it says that there is no sheeva plug connected....????
