Update 4.9k
What's hot...
Update 4.9k
Update to Meteohub V4.9k (NSLU2, x86, SheevaPlug, DreamPlug, iConnect, DC01) brings these features:
  • Fixes update HTTP password bug on DC01 platform.
  • Fixes backup function on DC01 platform.
  • Fixes a bug that prevents from reading data from EM1000 energy meter on some platforms.
  • Fixes a bug that prevents from showing graphs with evapotranspiration.
  • Extends demo period until end of October 2012 or 3 month, which ever comes first.
  • Improves reading Vantage datalogger to circumvent infinite loops when internally logged data does not report valid time stamps.
  • Fixed evapotranspiration evaluation for Vantages with solar sensor.
Update Link: http://www.meteohub.de/files/update-v4.9k.upd
cbhiii
Re: Update 4.9k
Post by cbhiii »
Does it also address the 'alarm log' entries for WindFinder? I keep getting these in the log which is in my daily log email. My data is going to the WindFinder site okay, but this entry is still seen.
2012.06.16 10:32:11 meteohub: weathernet: windfinder: upload to windfinder:
2012.06.16 10:47:10 meteohub: weathernet: windfinder: upload to windfinder:
2012.06.16 11:02:15 meteohub: weathernet: windfinder: upload to windfinder:
2012.06.16 11:17:14 meteohub: weathernet: windfinder: upload to windfinder:
2012.06.16 11:47:07 meteohub: weathernet: windfinder: upload to windfinder:
Re: Update 4.9k
4.9k does not address this, but may be one of the previous updates did.
What Meteohub version are you running?
cbhiii
Re: Update 4.9k
Post by cbhiii »
I updated yesterday to 4.9j. Running on an ebox 3300.
Re: Update 4.9k
Can you please grant me access by browsing to "http://ip-of-your-meteohub/cgi-bin/help.cgi"?
cbhiii
Re: Update 4.9k
Post by cbhiii »
It looks like my remote access is not up. I'm away from the house for a couple of hours. I will email you when back home. Thanks!
cbhiii
Re: Update 4.9k
Post by cbhiii »
I have ran that script on my site for you to gain access.
Re: Update 4.9k
I could drill it down to a timing problem. Will be fixed with next update.
Upload to windfinder works ok, it is just about the warning messages.
cbhiii
Re: Update 4.9k
Post by cbhiii »
Okay. Thanks for taking a look. I figured it was something like that.
jubi
Re: Update 4.9k
Post by jubi »
Two days ago I updated my alix server from 4.9e to 4.9k. First all looks good, but after some hours I recognized, that there is no data for the wind sensor. After some tries to reset the connection and the weatherstation, I tried to install older versions of the meteohub software.
At the end all is fine when I have gone back to version 4.9e, but after upgrading to 4.9f, 4.9h or 4.9k (no tries with g,i,j) the result is always getting no wind data.
My weatherstation is a Conrad/ELV WS444 which has a sensor for wind force but none for wind direction, which was no problem in the past (always north direction).
Please try to find the cause of this problem, so I can upgrade to one of the upcoming versions.
WS444 / Meteohub 4.9k @ Alix 1D
Wetterstation Langen
wfpost
Re: Update 4.9k
Post by wfpost »
Dein Problem kommt daher, daß du keinen Temp Sensor zugewiesen hast. (siehe rotmarkierten Text unten für die Lösung!!)
Seit 4.9g ist für die Windchill-Berechnung ein beliebiger TempSensor wählbar ...
Schaust du hier ...
viewtopic.php?f=14&t=8914
Re: Update 4.9h
Postby rst » 10 May 2012 10:05
Hallo,
habe seit einigen Wochen nach den Updates Probleme mit dem Auslesen des Windsensors der WS2300. Nachdem ich den Sensor getauscht hatte, ohne ein Ergebnis zu erzielen, bekam ich mit, dass der Sensor Daten an die Station liefert, aber diese nicht mehr vom Meteohub übernommen werden. Status wind0 "nie". Wurden diese Probleme auch von anderen WS2300-Nutzern angezeigt, oder bin ich der einzige...?
Viele Grüße
Ralph Stöcker
Ws2300
Alix1D
Neteohub 4.9h (Build 6549)
Re: Update 4.9h
Postby admin » 16 May 2012 22:22
Bitte mal auf der Seite "Wetterstation" den korrekten Temperatursensor für den Windchill zuweisen und "speichern" drücken.
Screen_20120712192559 von honsolgen auf Flickr
jubi
Re: Update 4.9k
Post by jubi »
Many thanks for this very quick answer.
That's it! After storing the windchill temp sensor all is fine.
