Meteohub receives no data from VP2
dibra
Post by dibra »
My system: Dreamplug with latest meteohub. Vantage Pro2 with Weatherlink IP.
Problem: Meteohub doesn't receive data from Weatherlink. Message is "data gap less than 10 minutes".
Logfile:
logger (28.06.2012 21:51:11): data logger (version 4.9, build 929) started.
logger (28.06.2012 21:51:11): connect station 0 (Vantage via TCP/IP).
logger (28.06.2012 21:51:12): station 0 (Vantage), wakeup sent.
logger (28.06.2012 21:51:12): station 0 (Vantage), init sequence sent.
logger (28.06.2012 21:51:12): station 0 (Vantage), internal logger activated.
logger (28.06.2012 21:51:12): station 0 (Vantage), syncing.
logger (28.06.2012 21:53:27): station 0 (Vantage), gettime request sent.
logger (28.06.2012 21:53:37): station 0 (Vantage), gettime request sent.
logger (28.06.2012 21:53:38): station 0 (Vantage), no Vantage time offset.
logger (28.06.2012 21:53:38): station 0 (Vantage), eeprom request sent.
logger (28.06.2012 21:53:39): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (28.06.2012 21:53:39): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (28.06.2012 21:53:39): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 166 secs
Re: Meteohub receives no data from VP2
When this happens only once in a while, no problem.
It probably happens when the ip-logger transmits its data to the weatherlinkIP site.
It was only so many seconds (see messages).
It simply means that the connection was lost for less than 10 minutes.
If it is longer than 10 minutes meteohub will read the vantage logger to get the missing records.
If less than10 minutes it is not worth the time spent and Meteohub starts recording the realtime weatherdata.
Hope this clarify things,
Wim van der Kuil
http://www.weerstation-leuven.be
