Mysterious system hangs, linux help needed
System stops responding on port 80 en stops uploads.
Meteohub should only upload data, no other interactions normally. But when data not arrives at website i try to login, no response.
Meteohub does not react to ping, shows no open ports at all using a port scanner.
Although i am not familiar with linux, i tried to read the logs.
Data area is only partly used, so thats not the problem.
I am always using on this "Meteohub ready system with VGA and WLAN, ALX3W" (meteohub says Alix1D) the WLAN interface. The other Meteohubs never hang, but they are using the LAN.
I included a system log.
The only strange thing i found that
Jul 4 13:16:22 meteohub kernel: spurious 8259A interrupt: IRQ7.
But that is the last entry before the hangs but that is days old.
Could the WLAN be the problem?
What should I look for in the log?
meteohublog.txt.zip
(8.82 KiB) Downloaded 376 times
che
Re: Mysterious system hangs, linux help needed
Post by che »
looks like I have the same problem. Every now and then, Meteohub stops uploading the graphs and the all-sensors-file. Today it was the third break in 2 weeks, before it worked without problems for 2-3 month. The problem obviously concerns only the WLAN, Meteohub itself works fine (calculating weather data).
Any idea what the problem might be?
Thanks, Christian
