Mysterious system hangs, linux help needed
Posted: Wed Jul 04, 2012 2:06 pm
System stops responding on port 80 en stops uploads.
Meteohub should only upload data, no other interactions normally. But when data not arrives at website i try to login, no response.
Meteohub does not react to ping, shows no open ports at all using a port scanner.
Although i am not familiar with linux, i tried to read the logs.
Data area is only partly used, so thats not the problem.
I am always using on this "Meteohub ready system with VGA and WLAN, ALX3W" (meteohub says Alix1D) the WLAN interface. The other Meteohubs never hang, but they are using the LAN.
I included a system log.
The only strange thing i found that
Jul 4 13:16:22 meteohub kernel: spurious 8259A interrupt: IRQ7.
But that is the last entry before the hangs but that is days old.
Could the WLAN be the problem?
What should I look for in the log?
