Error in [actual_thb0_press_hpa]?
HLucas01
Post by HLucas01 »
I have installed Meteohub 4.9k this morning and noticed that the actual barometric pressure that is on the front page of my website is reporting the wrong value.
This front page is generated and uploaded by Meteohub based upon a HTML template in the PC network folder "/public/graphs" (see chapter 3.4 in manual).
In Settings - Calibration i have always had a compensation of +2,8 Hpa on sensor thb0, because my weather stations readings have always been to low.
In uploads to weather networks (such as Awekas), the correct (2,8 Hpa higher) value is uploaded, so the compensation is still active.
The Meteohub value [actual_thb0_press_hpa] has (as far as i know) always reported the reading including the compensation, but now it is 2,8 Hpa to low.
Re: Error in [actual_thb0_press_hpa]?
press is without compensation, seapress is with altitude compensation.
HLucas01
Post by HLucas01 »
Using the seapress instead of press solves the problem, thanks !
