Perl plugin for TED-5000 Power and Filtrete 3m50 Thermostat
Cisien
Post by Cisien »
Here's a simple script I wrote up to get the temperature values, and mode from my WiFi-enabled thermostat, and Ted-5000 power meter, it should be very easy to extend to read (and log) other values that these two devices provide.
TED 5000
Filtrete 3m50
  • change the URIs in the script to point to your devices (I use DNS names to make my life easier)
  • copy this script to your meteohub device
  • chmod it to 777
  • configure meteohub with a new weather station
  • with it's source set to plug-in
  • set up the sensors
  • and done!
#!/usr/bin/perl
use strict;
use warnings;
use XML::Simple;
use JSON;
use Data::Dumper;
my $tedAPI = "http://ted/api/LiveData.xml";
my $tstatTempAPI = "http://thermostat/tstat/temp";
my $tstatTTempAPI = "http://thermostat/tstat/ttemp";
my $tstatTmodeAPI = "http://thermostat/tstat/tmode";
while(1)
        sleep(15);
        my $start = time();
        #TED Data
        my $tedXML = `curl --silent $tedAPI`;
        my $txml = new XML::Simple;
        my $teddata = $txml->XMLin($tedXML);
        my $kwh = sprintf('%.2f', $teddata ->{Power}->{MTU1}->{PowerNow});
        my $volt = sprintf('%.1f', $teddata ->{Voltage}->{MTU1}->{VoltageNow});
        #TSTAT Data
        my $ttempJSOut = `curl --silent $tstatTTempAPI`;
        my $json = JSON->new->allow_nonref;
        my $tstatTemp = $json->decode(`curl --silent $tstatTempAPI`)->{temp};
        my $tstatTTempHeat = $json->decode($ttempJSOut)->{t_heat};
        my $tstatTTempCool = $json->decode($ttempJSOut)->{t_cool};
        my $tstatTmode = sprintf('%.2f', $json->decode(`curl --silent $tstatTmodeAPI`)->{tmode});
        $tstatTemp = sprintf('%.1f', ($tstatTemp - 32) * 5/9);
        $tstatTTempHeat = sprintf('%.1f', ($tstatTTempHeat - 32) * 5/9);
        $tstatTTempCool = sprintf('%.1f', ($tstatTTempCool - 32) * 5/9);
        $tstatTemp =~ s/\.//g;
        $tstatTTempHeat =~ s/\.//g;
        $tstatTTempCool =~ s/\.//g;
        $tstatTmode =~ s/\.//g;
        $kwh =~ s/\.//g;
        $volt =~ s/\.//g;
        print("data0 $kwh"."\n");
        print("data1 $volt"."\n");
        print("t0 $tstatTemp"."\n");
        print("t1 $tstatTTempHeat"."\n");
        print("t2 $tstatTTempCool"."\n");
        print("data2 $tstatTmode"."\n");
        my $end = time();
        my $time = 45 - ($end - $start);
        sleep($time);
Re: Perl plugin for TED-5000 Power and Filtrete 3m50 Thermos
great, thanks for sharing!
meteo-quimper
Post by meteo-quimper »
hi
is it possible to build a plugin to get temperature data from a METAR ?
Cisien
Post by Cisien »
I don't have a METAR device, but it should be possible using what i've provided as a framework (Download XML/JSON from a web api, parse, output as data, every 60 seconds)
