[WMR 200] th0 loses connection
Vetinari
Post by Vetinari »
Hey all,
strange behavior from the outdoor temperature sensor:
2012.06.09 11:44:11 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.10 11:44:13 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.13 05:44:07 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.13 11:44:03 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.20 05:44:09 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.21 05:44:14 Meteohub: sensorfail: Sensor "th0 " failed
2012.06.22 11:44:13 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.02 05:44:04 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.02 17:44:06 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.02 23:44:07 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.03 05:44:04 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.03 11:44:07 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.04 05:44:05 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.05 05:44:05 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.06 05:44:14 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.06 11:44:06 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.06 17:44:09 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.07 05:44:09 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.07 11:44:11 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.08 05:44:07 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.09 05:44:07 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.09 11:44:14 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.10 05:44:13 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.10 11:44:10 Meteohub: sensorfail: Sensor "th0 " failed
Nearly every day on 05:44 a.m. or 11:44 a.m. the sensor loses the connection.
For me it seems so regular, that this cannot be only a random lose of connection.
Anyone have similar problems? Or any solutions?
wochips
Re: [WMR 200] th0 loses connection
Post by wochips »
Oddly, I have experienced the same problem with my WMR88 connected to iconnect running Meteohub 4.9k. At 05:44 every day over the last three days I get message that data has not been received for 30 minutes, uploading has stopped and all sensors show 'never'.
Reboot of meteohub cures problem and all is well until 05:44 next morning.
WMR88 UV
iConnect
Vetinari
Post by Vetinari »
I am running meteohub on sheevaplug with meteohub 4.9e.
But perhaps it is not only the sensor?! Can meteohub interfere in some way, i.e. a cron job or something that could cause the disconnection?
Here are some new data:
2012.07.13 11:44:08 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.14 05:44:15 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.14 11:44:10 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.15 23:44:05 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.16 05:44:08 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.17 05:44:11 Meteohub: datalog: Logging of Weather Data for more than 30 minutes without new data
2012.07.21 05:44:02 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.21 11:44:01 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.25 23:44:15 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.25 23:44:15 Meteohub: datalog: Logging of Weather Data for more than 30 minutes without new data
2012.07.26 05:44:02 Meteohub: sensorfail: Sensor "th0 " failed
2012.07.29 05:44:11 Meteohub: sensorfail: Sensor "th0 " failed
In March or May I changed the batteries but at that time all seemed fine. I will check the batteries once again.
Luckily only the th0 sensor is affected and I do not have to reboot. After some time the connection of the sensor is established again or I have to manually search by using the WMR-200 central station.
@wochips, you do not have a solution until now, do you?
RF conditions of WMR 200 are not the best. try relocating sensor or console.
wochips
Post by wochips »
I previously had a problem with dropped sensors for 30 minutes causing the upload to shut down but after changing to a much shorter usb cable than the one supplied with WMR88 the problem went away. The problem returned for three days failing at 05:44 each day with nothing in my set-up being moved or changed, however, today there was no problem.
I do lose the th0 sensor once or twice a day but these losses are temporary and only cause the occasional loss of one upload so are not a problem.
WMR88 UV
iConnect
