I have meteohub running perfectly on the alix 3D2, i also have the blitzortung controler board (usb) connected to the Alix 3D2 board. i use the file to install the linux tracker (linux program to send data from the controleer board to the blitzortung server): http://wetterstation-littau.ch/download ... racker.pdf
Meteohub is working if i manualy start the tracker program with :
/etc/init.d/tracker_S20 start
If i program an antomatic start (when the alix board start) with
update-rc.d tracker_S20 defaults
I try to delay the automatic start of the linux tracker (i added sleep 240 on the file tracker_S20), i have the same problem.
tracker_S20:
#! /bin/sh
## Programmeinstellungen
sleep 240
PROGDIR="/blitzortung/"
PROGNAME="tracker_Linux"
LOGFILE="-ll /blitzortung/log"
GPSTYPE="SiRF"
DEVICE="/dev/ttyUSB0"
BO_USERNAME="Login"
BO_PASSWORD="Password"
COMMAND="$PROGDIR$PROGNAME $LOGFILE -vl -vo -vi $GPSTYPE $DEVICE $BO_USERNAME $BO_PASSWORD 1"
# Aktionen
case "$1" in
start)
$COMMAND
stop)
killall $PROGNAME
restart)
$0 stop
$0 start
esac
exit 0
