Weather exchange data format data.csv
Does anyone know if there is a way to have Meteohub export a data.csv file in Weather Exchange data format? Most of the the Weather software outputs this file every 5 seconds and then have the ability to send it by ftp. I have look and look and I can't seem to figure it out.
Re: Weather exchange data format data.csv
Anyone ever figure this one out??
not supported and never heard of that format.
All data in Meteohub is in flat files in a documented format, so you can easily do your own export program.
Would this also be true for Meteobridge?
Also here is the info for the data.csv format,
http://site.ambientweatherstore.com/vws/vwsmanual.PDF page 52 "7.2 CSV File export", however even though this says "Export" you can import the data.CSV file into VWS and use it to display weather data in VWS using the "Station-less" mode. So if meteohub and/or Meteobridge had a push option to create a data.csv file you could use it to display the data collected on a single instances or multiple instances of VWS, also this data.csv file can also be used with WD in station-less mode, possibly other Programs also.
Please consider adding this for a future release.
There maybe a way to wright a script to do this but I haven't looked into it, anyone up to the task?.
George
http://n1naz.myds.me/weatherweb/index.php
George
